Question about Weber-Stephen Products Repl Grill Lid Handle grill repair parts
My handle is broken, the mecanism for withdrawing is working . I am missing the protecting part is it available?
  • monica_odens Jan 04, 2011
    samsonite. I do not find any other info in the guarantee folder. The lock number is ref. N.B-100/9811
    below is written 8668-SPAR/01-99
    Can you make it with this information?
  • 8,197 Answers
May I get the make and model # to help you more
Posted on Jan 01, 2011
Replace outside door handle 1992 somina
Exterior door handles of vehicles are fairly straightforward things to replace once the interior trim panel or door card and waterproof membrane have been removed and these things are often less than straightforward with hidden clips and screws. A repair manual makes the process simpler if you haven't much experience.
The screws or nuts securing the door handle are then accessible with the window up. There is probably a link connecting the handle to the door catch but not always and if the handle also contains the lock there might be a second link connecting to the door catch. Sometime it is easier to release the links from the door catch and withdraw them with the handle and sometimes it is easier to disconnect at the handle before removal. Sometimes it is easier to withdraw the handle a little way and unclip the link(s) outside the door.
In nearly all cases it is a task that is complicated and fiddly the first few times but incredibly simple later on. Look forward to breaking plastic clips, especially in cold weather, and a feeling of frustration.
The best advice I can offer you is make yourself comfortable and don't try to hurry. Have an assistant standing by but don't allow her to distract you. Work in twilight or under overcast skies or deep shade so the shadows aren't so deep ordinary torchlight needed to see inside the door gets lost and you are working blind.
Don't forget to fit the gaskets to the new handle before refitting. Finish by lubricating whatever can be lubricated inside the door, testing whatever can be tested and then washing your hands before refitting the membrane and door card.
Mar 01, 2015 | Cars & Trucks
Need handle replacement and power cord for sunbeam mixmaster mmb
NelsonEZY.com stocks the power cords. The handle should be available on eBay. NelsonEZY com home page
Mar 22, 2014 | Sunbeam Vintage Chrome Mixmaster Mixer Mmb
Getting the broken tailgate latch out and the new one in
TO REPLACE TAIL GATE LATCH. TAKE A SMALL SCREW DRIVER OR USE A TRIM TOOL PRY OFF THE HANDLE ESCUTCHEON. ONCE BOTTOM PRIED OUT PULL THE ESCUTCHEON DOWN AND AWAY FROM THE TAIL GATE.IF YOU USE SCREW DRIVER COVER TIP WITH ELECTRICAL TAPE TO KEEP FROM DAMAGING PAINT SURFACE.FROM THE BED SIDE OF THE TAIL GATE REMOVE THE HANDLE MOUNTING BOLTS ROTATE THE PLASTIC RETAINING CLIPS OFF THE CONTROL RODS AND REMOVE THE RODS AWAY FROM HANDLE.REMOVE THE BOLTS AND WITHDRAW THE LATCH FROM THE END OF THE TAILGATE.
Aug 28, 2011 | 2005 Chevrolet Avalanche
I can't get the old broken window crank off.
Are you talking about the old style window crank? If you are, then they are usually held on by a c-clip located behind the handle. There is a special tool that is available at most part stores. The tool slides under the handle and pushes the clip off. Once the clip is removed, then the handle should come right off. It also works for old style door handles.
May 19, 2011 | GMC Sonoma Cars & Trucks
I am looking for a new rounded handle bar that you use to push the stroller along with. The foam on my one is damaged
unfortunately I believe you have to buy a new chassis jus for the handle bar. The best way is to just buy a handle bar cover for the handle bar. That will cover the damage and also protect it from further damage.
Sep 17, 2010 | Bugaboo Cameleon Stroller
The latch handle does not work on the rear cargo door. I can't open the door. It appears that the handle mechanism is broken.
I would pop off the rear hatch trim to look inside to see what is broken. Usually there are a bunch of push pins that hold the trim in place.
Aug 09, 2010 | 2000 Toyota Sienna
Driver side door won't lock or unlock with key
youll have to take the door panel off and look for a rod or a clip that came undone its an easy fix
May 06, 2010 | 1996 Volkswagen Cabrio
Back window latch is hung on our 2005 chevy tahoe. how do we get it unhung
For any electrical type latch/control I suggest to shoot brake cleaner spray (protect the paint around working area with rag) and push button at repetition during it's still wet. It helps to clean internal contacts.
For any mecanical type latch/control I suggest penetrating oil such WD4. (also protect the paint around working area with rag) and operate mecanism at repetition during it's plenty of oil)
For both, repeat the procedure if not sucessful on first attempt.
I don't have in head the exact mecanism design for your vehicule. Sorry if I can't say more about.
Hope it will help
Dan
Dec 20, 2009 | 2005 Chevrolet Tahoe
LG 14" TV & Video Combi - video is stuck, any ideas how to get it out?
this a mecanical problem inside video drive (gears broken/used has jamed the mecanism), need to repace mecanical mecanism. go to local repair store to replace and check for clean heads for quality operation.
Nov 22, 2009 | LG V271 DVD Player/VCR
How do I cancel my Yahoo account?
Delete Account in yahoo
https://edit.yahoo.com/config/delete_user
In windows operating software go to add/remove programs and delete all yahoo related software. Run a software like glary utilities (http://www.glaryutilities.com/) (freeware) to remove all broken link registry keys.
Dec 26, 2008 | Yahoo Mail
Weber-Stephen Products Repl Grill Lid Handle grill repair parts Logo
Top Weber-Stephen Products Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Weber-Stephen Products Grilling Expert? Answer questions, earn points and help others
