Question about Raymarine St 4000 Wheel Drive E12093
MKII E12093 Wheel Drive
The installation kit to mount the wheel drive is for the smaller diameter steel wheels. Is there a adapter kit for wooden wheels?. My original 4000 had black plastic "U" shaped adapters.
  • 38 Answers
Try to make new brackets for adapting to the screw holes on the rim ATTENTION the screws should NOT
go deeper in the rims as the original ones as they will interfeer with the internal parts and damage will result.
Posted on Jun 21, 2010
How to change front wheel bearings on a 4 wheel drive dodge nitro?
HUB AND BEARING
1. Raise and support the vehicle.
2. Remove the tire and wheel assembly.
3. Remove the caliper adapter. Refer to Brakes/Hydraulic/Mechanical/CALIPER, Disc Brake - Removal.
CAUTION: Never allow the disc brake caliper to hang from the brake hose. Damage to the brake hose will result. Provide a suitable support to hang the caliper securely.
4. Remove the disc brake rotor. Refer to Brakes/Hydraulic/Mechanical/ROTOR, Brake - Removal.
5. Remove the wheel speed sensor. Refer to Brakes/Electrical/SENSOR, Wheel Speed - Removal.
Fig. 47: HALF SHAFT BEARING BOLTS
6. Remove the axle shaft nut. (if equipped with four wheel drive)
7. Remove the three mounting bolts (1) for the hub. bearing assembly.
8. Remove the hub/bearing.
Installation
INSTALLATION
Fig. 48: HALF-SHAFT BEARING BOLTS
1. Install the hub/bearing assembly to the vehicle.
2. Install the three mounting bolts (1) for the hub/bearing. Tighten the bolt to 130 N.m (96 ft.Ibs.).
3. Install the axle shaft nut. Tighten the nut to 135 N.m (100 ft.Ibs.). (if equipped with four wheel drive)
4. Install the wheel speed sensor to the hub. Tighten the bolt to 13.5 N.m (10 ft.Ibs.). Refer to Brakes/Electrical/SENSOR, Wheel Speed - Installation .
5. Install the disc brake rotor. Refer to Brakes/Hydraulic/Mechanical/ROTOR. Brake - Installation .
6. Install the disc brake caliper adapter. Tighten the nut to 135 N.m (100 ft.Ibs.). Refer to Brakes/Hydraulic/Mechanical/ROTOR, Brake - Installation .
7. Install the tire and wheel assembly. Refer to Tires and WheelsAYheels - Standard Procedure . 5250a498-52fa-4c0c-8687-d0c1ee25e9f7.jpg Auto Repair Help US
Sep 02, 2014 | 2007-2011 HA590245 Dodge Nitro Front Wheel...
Raymarine St 4000 Wheel Drive E12093 malfunction
This is a good device. Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Apr 25, 2014 | Raymarine St 4000 Wheel Drive E12093
What does a rear axle look like
Your rear axle is the part that runs between the two rear wheels. The shock absorbers and springs are always attached to it. On a rear wheel drive or four wheel drive vehicle there is a bulge in the center of the axle where the gears are located. On a front wheel drive car, the axle may just be a length of box steel. On a rear wheel or four wheel unit there are drive axles inside the housing that connect the gears to the wheels. On front wheel drive there is a spindle on each end with bearings and a flange to mount the wheel.
Dec 28, 2010 | 1994 Ford Crown Victoria
Can the 12093 operate without something else. just need something to hold a preset direction ..dont need to know direction, just hold course
The wheeldrive is only a mechanical actuator ,it will not pilot ,it will only drive the wheel ,you need a control unit ,several 4000 or 3000 units are suitable ,
some have an internal compass others need an external compass
May 23, 2010 | Raymarine St 4000 Wheel Drive E12093
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
Apr 06, 2010 | Raymarine St 4000 Wheel Drive E12093
Autohelm 4000 ST fails to drive
CHECK INSIDE
BELT CONDITION
RUNNER BROKEN OFF
CHECK OUTSIDE
CLUTCH LEVER PIN BROKEN ,CLUCH LEVER OUT OF POSITION
BELT TENSION ADJUSTMENT WRONG (REMOVE SMALL COVER PLATE (+- 10mm Dia)ON REAR OF BACKPLATE ,LOOSE SPECIAL NUT ADJUST WITH ALLEN ,TORQUE NUT,PUT COVER BACK
Feb 19, 2010 | Raymarine St 4000 Wheel Drive E12093
Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
Dec 18, 2009 | Raymarine St 4000 Wheel Drive E12093
I need the dimentions for a 95 swift rim... the inside diameter hole i already know it is a 13in 4x4.5
You've just about stated all the numbers that you can ever possibly need! Yes, the standard 13" wheel is 4.5" wide, has 4 stud holes intended for 12mm studs which are on a pitch circle diameter (PCD) of 114.3mm (the Japanese version of 4.5"). The only thing you haven't mentioned is the offset of the rim. This is the distance from the mounting hub face of the wheel to where the middle of the wheel is (halfway between the outer and inner rim edges. For a front wheel drive car, this number is usually always positive and I think it is 35 or 45mm for this wheel. If you have an original steel wheel, it should be stamped on the outer rim area near the valve (along with other identifying info).
Oct 07, 2009 | 1995 Suzuki Swift
Raymarine St 4000 Wheel Drive E12093 Logo
170 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
