Question about Behringer Audio Players & Recorders
I have a behringer EP1500 amp, connected to a behringer mixer VMX100. i am getting a popping sound, the sound is random, it happens at various times, so i cannot say it always happens after i have performed a certain action. i connected the amp/mixer to my pc, then my laptop, happens with both devices, so guesing it is not the pc / sound card. what do i try next? tx
  • Behringer Master
  • 6,694 Answers
check the power outlet socket to which the amp and mixer is connected. if there is any loose contact in that power socket, this problem can occur. try to use a good surge protector with emi filter for connecting the amp and mixer.
ok
Posted on Dec 29, 2010
Crackle sound
dirty slide switch/rotary pot. clean with contact cleaner or wd40
Feb 20, 2014 | Behringer Xenyx 1204USB USB Mixer
No sound from amp. Turns on, but seems to be clipping out and is popping. Any troubleshooting advice?
check the connector where your instrument cable comes in. Make sure you are getting a good connection. Unfortunately, there is likely a bigger problem.
Jul 23, 2012 | Behringer ULTRACOUSTIC ACX1800 2x8...
Line/Phono switch? Cant find them
Look on the switch for a brand name... often they use a lot of ALPS products. I normally search DigiKey.com and Mouser.com, and Allied electronics and Newark.com.
Behringer online is of little help. I have called them and got parts directely. They don't stock a lot and sometimes it takes a little while to get the product.
May 06, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer pmh mixer manual. 20 channel 800watt powered mixer no speaker output. I need to test the power supply and the amp modual. Thanks
Are there lights or effects windows lit up? If so, the power supply is likely OK.
If neither speaker is working, that is bad however make sure all your trims and sliders are right to send audio through. Some have a standby switch.
This probably has an HCA2400 amp board in it and those can burn up for various reasons including loose speaker cables.
Nov 28, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
We've got a signal on the mg32fx14 mixer from the microphone. There is no sound from the speaker. We tried the Group out there is no sound. So where do we connect the output from the backpanel of the mixer...
mg32fx14 monitors intermitently cut off, smoke comes out the back . aux 2 changes aux 1 and aux 2 at same time. 1 channel will over drive then change channels without changing enything else and its ok eny ideas or do i have a boat ancor
Apr 02, 2009 | Yamaha Mg3214fx 32 Channel Mixer With Fx...
Behringer 1500 red light. Amp powers up fan comes on then a have a channel A red light that doesn't go out. No Sound
RED LIGHT MEANS THERE IS EITHER WIRES TOUCHING OR A BAD GROUND. IN WORSE CASE SCENERIO THE A CHANNEL IS BLOWN
Feb 23, 2009 | Behringer EUROPOWER EP1500 Car Audio...
Behringer ep1500 versus behringer eurolive b215 X 2- pa speakers.
The Amplifier will have wierd, notched, circular speakon cable connectors on the back, two, one for main left and one for main right. Press the button in on your speakon cable connector and twist it and lock it into place on the amplifer for right and left attachments, then do the same to your speakers.
Hopefully this helps.
Michael Lazar
http://www.AudioholicBlog.com/
Aug 27, 2008 | Behringer EUROPOWER EP1500 Car Audio...
Connecting a behringer djx700 mixer to a panasonic amp
The problem is most likely between the turntable and mixer. You need to be sure that the turntable is connected to a phono input. I'm not sure if your mixer has one. If not, you need to have a phono pre-amp between the turntable and the line input on the mixer.
Check that first and get back to us if you still have problems/questions.
Dan
Aug 21, 2008 | Audio Players & Recorders
Connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
Aug 08, 2008 | Phonic Audio Players & Recorders
343 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
