Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
I think my mouse battery might be dying :(
So I have my mouse charged and has plenty of batteries and works fine 90% of the time. That other 10% of the time the mouse LED flashes red for a second and the mouse is unresponsive. I have experimented and even when the mouse isn't connected to anything and is just on, it will still flash the low battery light. Do I need to replace the battery or is it just better to replace the whole mouse? I doubt the warranty is still good.
  • Redtide Jul 07, 2008
    Can someone give me a link to a good tutorial on at least how to open the mouse and mess with the battery?
    Sergeant:
  • 287 Answers
Depending on how old the unit is, the rechargeable battery may well be faulty. I believe theis mouse comes with a 3yr warranty though. I suggest you contact logitech for a warranty claim
if less than 3 years old.
The other option may be to open up the unit and replace the battery yourself.
read THIS thread on the logitech support forum.
Good luck
Posted on Jul 07, 2008
    Scholar:
  • 148 Answers
Check the connections at the battery you might have to bend the silver tab closer to the battery or stick a little aluminum foil to the battery as you put it in
10" netbook (N series) NP-N150 does not want to turn on. it only shows an orange light when charging
What about with battery out will it turn on wit h the power adapter plugged in
Jul 12, 2013 | Computers & Internet
R530 switchesoff
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the battery dropsoff to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 12, 2012 | Samsung R530 Notebook
My cell phone battery dies much quickly
Some cell phone batteries work fine for a short period of time and then rapidly diminish their holding capacity. The battery that has previously worked fine for 10 days standby begins a downward time drop to last merely a couple of days. A simple procedure that I have found to be invaluable is to:
1. Turn the power to the phone off.
2. Remove the battery from the phone.
3. Replace the battery into the phone.
4. Fully charge the battery.
5. Test the results by noting the time and day of item 4 above. Leave the phone on standby and see if the charge will now last many days. If so, congratulations, your phone is almost as good as new, and you didn't need to find and buy a new battery (or bother the customer service staff).
Feb 05, 2012 | Sharp Cell Phones
I have a suzuki boulevard c50. The battery died over the winter and had to be charged. It has failed to crank 2 times since then. I jumped it off and rode for about 50 miles home after turning it off it...
It sounds like it is time for a new battery. While the regulator could have been damaged during the jumping procedure, the symptoms you've outlined still point to a bad battery. Motorcycle batteries do not fair well from a complete discharge. Sometimes removing the all of the acid and replacing with new acid will provide another year of service, but not always.
My reasoning for the thinking it is the battery is because of it not being kept charged over the winter and it was working fine before then (charging system usually does not get damaged from non-use). If the bike died when you removed the cable while it was idling, this would suggest the battery as well as a magneto based charging system is very weak at idle and relies on the battery to supplement it during periods of idle. To test my theory, jump the bike off, rev it to 1200 to 1500 RPM and disconnect the jumper cable. If the bike continues to run but dies when you let it idle, then the charging system is functioning and the battery needs to be replaced.
Apr 10, 2011 | Suzuki Boulevard C50T Motorcycles
Battery is dying after 10 min talk time
Normally when a battery does that it has to do with it's very first charge. If the phone was turned on at all before the first charged reached it's full capacity, one day out of no where it will just die very quickly. You should also notice that when it charges it reaches a full charge more quickly than it did before. If that is not the case then you just got a defective battery. I can tell you for sure it doesn't have anything to do with the memory card.
Dec 28, 2009 | LG Dare VX9700 Cell Phone
2002 chrysler sebring 2.7 v6 elictrical problem???
Sounds like a charging system issue. Just because the alternator itself tested fine doesn't mean it's getting power to the car and battery. Charge the battery and start the car (with everything connected normally, including alternator). While car is idling, disconnect the battery (negative post wI'll do). If car dies, there's a problem with the alternator wiring/harness. Once the vehicle is running, the alternator should provide plenty of power. Check voltage at battery (from alternator) and should be around 14V. Check alternator fuse.
Could be the voltage regulator in the alternator going out, which would need a new alternator.
May 01, 2017 | 2002 Chrysler Sebring
NEW ALTERNATOR, NEW BATTERY, CAR still dies and wont start
Check the main power fuse that goes to the alternator output. if the alternator went out it could have burnt this fuse also.
Jun 26, 2009 | 1990 Acura Integra Hatchback
Trouble on startup
sounds like alarm isnt ground properly..
Apr 21, 2009 | 2001 Chevrolet S-10
Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Nov 16, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Powerlocks
i shoul not afect any thing unless you replace the batterie with the car runing, and some radios have antitheft code if batterie die or disconect the radio will ask you to type a code in order to work again but most of times it display the worl code on the digital screen
Jun 11, 2008 | 2004 Dodge Neon
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
208 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
