Question about Fisher and Paykel IWL12 Top Load Washer
The spin red light and 2 green wash lights in between the short and regular was cycles on and alarm sounding. Washing machine has stopped about 3/4 of load filling up.
  • 1,557 Answers
Its got a bad read sensor it needs to be cleaned its under the capstan drive motor take the part out and clean is ir readers
Posted on Dec 29, 2010
  • 2 more comments
  • alelphege Mar 23, 2011
    hey i have that same issue, the spin red light and the green lights are flashing and beeping, but where do i find the bad read sensor? do we need to open it from the back and clean it out?
  • sonic boom electronics
    sonic boom electronics Mar 23, 2011
    from the bottom take out the capstan by removing the big white lug
  • idsky May 20, 2011
    And if after cleaning the sensor, the beeping and above error lights continue, do I need a new sensor part? 425221P I think (machine back together now).
    sonic boom electronics May 21, 2011
    yes replace the sensor
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Gw712
66. (01000010) Phase 6 - Pressure Transducer (Ptx)
Error - Frequency > 90 kHz
Note: this supersedes Fault code 65 from V41 Motor Control Module
code onwards.
The Motor Control Module has received signals from the water level
sensor (Ptx) above normal frequency values.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Apr 22, 2012 | Fisher Paykel EcoSmart GWL15
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Machine wont work
Your machine probably needs re setting hold power down for 60 seconds see if that works
Apr 15, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel IWL12 Top Load Washer Logo
476 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
