Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
Once the heater reaches the set temperature at the thermostat it shuts off....completely. The flame goes out, pilot light goes out, and i have to manually ignite again. I had this problem a year ago and i tapped on the valve assembly (The part where the black gas knob is located on) and it worked for a few weeks....meaning it shut off at the set temperature, and kicked back on automatically when it got too cold. Now it just shuts off when the temperature at the thermostat is reached.
    Genius:
  • 1,015 Answers
It sounds to me like you have some small dirt or rust particles inside the gas valve that are hindering the valve from fully opening. Before I spent the money for a new gas valve I would make sure that the burners were clean and also clean pilot orifice. Replace thermocouple if it appears to be burned or deformed. You can turn thermostat up a little bit at a time and try tappimg on valve body to see if you can get it to free up. Unfourtunatly there are no repairable parts insid the gas valve so if it comes to that you will need to replace the valve. Hope this helps you and thanks.
Posted on Dec 30, 2010
My pilot stays on on my propane furnace but will not light up
The Little Giant units use a Unitrol gas valve very similar to a water heater in the home. #1,urn the Unitrol gas valve to the "PILOT" position to ignite the pilot. Depress the plunger and hold it down then push the spark igniter button until you can see the pilot flame ignite.
You have a lit pilot so this is not a problem for you.
The pilot light stays on continuously by design.
Once the pilot flame is established, you then turn the on/off/pilot valve to the "ON" position and set the thermostat to the desired temperature range., it should then fire its main burner until the desired temperature is reached. Once the temperature is reached, the main burner will shut off and the heater will go into a standby mode with the pilot flame still burning.
If you have turned the pilot valve to on and set the temperature high, it should come on, if not a new gas valve is required, they can be very difficult to replace due to rust.and most cases require a new unit,
Mar 19, 2015 | Unitrol Propane Heater Valve - Little...
Why does the heater turn off?
If it's thermostatically controlled, if shuts off the burner when it reaches the set temperature. Is the pilot flame going out too? These heaters require a certain amount of fresh air to operate properly. If the oxygen level gets too low, it is designed to shut off completely for your safety.
Mar 15, 2015 | Procom 10K BTU, Vent Free, 2 Plaque...
I start the pilot up... burners go on but once it reaches temperature the burners shut off and dont start up again????/ what could be the proble
Hi there.
Check the thermostat, it may have a mechanical defect (not closing contacts once it reaches the cut-in temperature).
If the pilot flame goes out with the burner flame once the ste temp is reached, your fryer may have problem with the hi-limit (premature tripping).
Regards.
Dec 01, 2013 | Imperial Kitchen Appliances - Others
Outlet water gets so hot it ballooned the PVC pipe like an anuresum. Lights and shuts down, assuming that is a limit switch working properly. Filters cleaned last month/water pressure seems adequate.
Your thermopile that tells the heater how hot the water is has failed. It should kill the heat at a temperature of 104f. This also indicates that the limits are not doing their job, as they should be killing the heat at 135f (low limit) or 150f (high limit). Schedule 40 pvc is rated at about 140f.
This many failures at once is rare, and typically indicates that the heater has been rigged. Get a tech out to fix it correctly. You are literally playing with fire.
Nov 28, 2013 | Hayward H Series Pool & Spa Heater 400k...
Pilot light wont stay on. How do you adjust pilot flame? Pilot flame doesn't reach temperature sensor.
then the pilot is blocked needs cleaning out or try blowing it out with air , or undone pilot and remove pilot injector and clean it .
Nov 01, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Fryer does not shut off when temp .is reached
I assume it is a gas model. There are 2 thermostats. One is adjustable, you set your temp, it sounds like it has gone bad.. The second thermostat is the high limit thermostat. When it reaches 450 degrees F, it will shut down the pilot and main flame to prevent a grease fire. It may be possible that someone has hooked the thermostat up wrong. Next time you fire it up, disconnect one of the thermostat wires that has the temperature knob. If the flame goes out, the thermostat is bad,
Oct 04, 2010 | Imperial IFS40 Deep Fryer
Furnace cuts off before reaching set temp.
You can make sure it is not the thermostat by crossing or jumping the R and W terminals (or associated wires) together. This will keep the furnace calling for heat. As it is approaching set temperature, get in front of the furnace and inspect the air filter to make sure it is clean, watch the control module for any error codes that may be turning off the system prematurely.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 07, 2010 | Honeywell Programmable Thermostat Heater
When my heater reaches the temperature, and flame goes to pilot, the pilot light goes out mainly when it is on a higher setting.
This should like you need to replace your ODS pilot assambly. You can find the manufactuer at www.desatech.com . They offer manuals and part distributors listings.
Jan 08, 2010 | Desa International GWP20T GLOWARM Wall...
Pilot going out
sounds like a bad thermostat.I am not to familiar with this problem.
sorry i could not be more help
Nov 23, 2008 | Heating & Cooling
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
194 people viewed this question
Top Williams Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
