Question about AudioCodes MP-112R/2FXS/3AC/SIP-3/UC ANALOG VOIP GATEWAY [mp-112r2fxs3acsip3] Router
My audio code mp 112 voip gateway is not going to console and bootp is also not find the device but device showing connect to lan port please give me solution
MediaPack MP114 - 4FXO Doesn't work
Install wireshark on your PC and connect yoour PC directly to the MP, once there power on the MP and see if any bootp/arp message appears on wireshark if nothing shows up, your device is bricked.
Nov 06, 2013 | AudioCodes MediaPack MP114 - 4FXO
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Unable to access a fresh Audio codes box via http using default IP address.
What IP address are you pointing at? 10.1.10.10? 192.168.0.1? try with 10.1.10.10 and worst case scenario install wireshark on your PC and take a trace when connected directly to MP and power it on, there you will see some bootp messages (IP address 0.0.0.0) and after that you will see messages from MP announcing its IP address. If device is brand new you should login fine using Admin / Admin. Beware that some internet explorers do not allow login even with right user/password, try with a couple of them.
Aug 22, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
May 05, 2011 | Nintendo Wii Console
I have a 1 port fxs voip voice modem, i have connected it and it is working. but the problem is that any time i power off my pc, i will have to reprogram it. can any body help me please?
the pc and ata are not reliant on each other. ensure the ata is plugged directly into you router.
unplug the lan lead and do a factory reset the ata via the ivr. once the unit has restarted plug in the lan and get the ip address via the ivr. set up the ata, rebooting after each page update (do not update more than 1 page before rebooting the ata).
you should now have a functioning ata and should be able to turn off your pc without issue.
if the ata now loses its settings then it is probably faulty (I've had a couple of ht386s go faulty in a similar way).
Apr 03, 2011 | Gateway 1-Port FXS/FXO VOIP (MTSMVP130)
Patton SIP / VoIP problem behind TZ170W
Please look into the chapter 34 in the guide which you can download from the following link
http://www.sonicwall.com/us/support/230_2749.html
Oct 28, 2008 | SonicWALL TZ 170 Wireless (01SSC5903)...
I have a ZyXEL P-660HW-TI ADSL wireless router used as the gateway and wireless AP (also the wired ports are used for LAN). It has no VoIP ports. I do have a 2nd ADSL router (not used: no wireless, 1 LAN...
No because the VOIP need to be loged in first. if you have the voip first then the wireless router and you turned off the router dchp section part of the wireless modem then perhaps it will work, plus you need a voip account.
Jul 03, 2008 | Computers & Internet
AudioCodes MP-112R/2FXS/3AC/SIP-3/UC ANALOG VOIP GATEWAY [mp-112r2fxs3acsip3] Router Logo
245 people viewed this question
Top AudioCodes Computers & Internet Experts
Mick Bowen
Mick Bowen
Level 1 Expert
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
