Question about Altec Lansing VS2421 2.1 Speakers
Well this is the closest to what i have. i have the vs2621 set. i plugged it up accordingly but no sound??
What is the cylinder numbering
Is this a 6 cylinder? if so, the #1 cylinder is the back head, (closest to the firewall) closest to the timing belt. 123 are on that head, 456 are on the front head (closest to the radiator) 4 being closest to the timing belt.
Jul 19, 2014 | 2003 Honda Accord
My aux port is not working
it sounds like something with the contacts is wrong
May 28, 2012 | Altec Lansing VS2621 Speakers
Right Speaker not working... The bass and left speaker work fine but I'm getting no sound off the right
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps you
Sep 23, 2011 | Altec Lansing VS2621 Speakers
I hav altec lansing vs2621, some times sub woofer not working. left and right speakers ok.
Hello
Check its speaker. In subwoofers, the lead wire that goes to the voice coil; goes from the speaker solder terminal to the vocie coil will get internal break and this type of fault sill occur. Intermittent working of speaker will be the result. Lead wire can be replaced. It can be bought from the electronic spare part shops. It is a type of copper braid wire. If you have the skill, fid out which wire is faulty and replace the same. you have to take out the speaker out of the box for repair. Broken wire can be detected by measuring its resistance with a multimeter. OK.
Jun 20, 2011 | Altec Lansing VS2621 Speakers
All I hear is a hum, the speakers aren't working and I know that they are hooked in correctly. Just want to make sure.
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 19, 2011 | Altec Lansing VS2621 Speakers
What is the order of the spark plugs for my 1991 Honda Accord?
Looking at the distributor straight on order is this 1 2
3 4
On th engine it is 4321 from distributor meaning the timing belt side is the #1 and the #4 is closest to the distributior,, This of course is for the 4cyl and not the V6, The 4 was way more common than the 6 and there was no specification.
Oct 24, 2010 | 1991 Honda Accord
I need the proper firing order for a 1987 chevy s-10 blazer v6 2.8
According to AutoZone's online guide it's a straight firing order of 123456. The odd cylinders are to the back while the even numbered ones face the front of the car. Begining with #1 (backside) closest to the pulleys, you then cross forward over to #2 (frontside) closest to the pulleys. Then back across to the next which will be #3, and so on.....
Dec 12, 2009 | Spark Plugs BR4HS Plug 10/BX #3322
Timing marks on 1992 honda accord 2.2l
The cam points UP, either pull the rubber access plug to see your flywheel/flex plate marks aligned with the pointer inside or stick a long screw driver inside the spark plug hole closest to your cam gear (with spark plug out). Turn the main pulley counter clockwise (bottom end) with a 3/4 or 19mm socket until the screw driver is raised as high as it will go. This will show you TOP DEAD CENTER.
Sep 15, 2009 | 1992 Honda Accord
New starter in 1997 honda accord. Bolt closest to
is it in the starter or the trans? In the starter, replace the starter. In the trans, you may need to have someone repair the threads with helicoil, or you can put some locktight on the bolt, get it fairly tight, and it should set up.
Jul 03, 2009 | 1997 Honda Accord
Altec Lansing VS2421 2.1 Speakers Logo
22 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
