Question about Lexmark Office Equipment & Supplies
My x1150 will not print a letter although the gauge is showing plenty ink in the cartridges.
  • 148 Answers
Have you selected the lexmark x1150 as the printer you want to print to in your application?
Posted on Jul 09, 2008
I have an HP color printer. When printing the black does not print well even though it shows that the black print cartridge has plenty of ink in it. Is there a way of: 1. Diagnosing if it is the print...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | HP Deskjet F340 All-In-One Printer
I just changed my cartridges for my lexmark x1150 and my blues are now showing pink.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 03, 2010 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Turning off color when no more ink
It should print as long as the letters color selected is black.
Dec 22, 2008 | Canon S 530D InkJet Printer
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
X1150: Uneven print with some words lighter second page on
I had bought a re-inked black cartridge from Staples; although my computer said that the cartridge was full, it wasn't working; I removed and put in a regula 16 black from Staples brand and now everything is fine. Thank you
Nov 24, 2008 | Lexmark X1150 All-In-One InkJet Printer
Leaking Ink Jet Cartridge.Clogged Up My X1150 Printer
No Solution Found.Get Lexmark Customer Services To E Mail Me Or I Take It Back To Trading Standards. C>Craske
Oct 07, 2008 | Lexmark X1150 All-In-One InkJet Printer
Pictures coming out yellow
The "Print Head" needs cleaning or replacement. It's the part that delivers the ink from the cartridge tank to the paper itself.Mostly caused by air entering the lines and making any residual ink cure.
Most newer printers only ever use 95% of the available ink before reporting tank is empty,and will not allow any printing to resume, preventing air being introduced to empty lines in the head.
Without Removing Anything
There's commercial products available, I guess a bit like using a head cleaning cassette in your VCR - I Have not tried any of these yet.
Use an empty ink cartridge Refilled with hot water and run the print head cleaning function.
( Dont worry , The paper will absorb the minute amount of water being dispersed.)
If that fails you should remove the print head cartridge most are pretty easy ,
LexMark X1150 X1185 and other similar models with the sensor strip running through the cartridge instructions are located at the following FixYA topic
http://www.fixya.com/support/t181337-piece_fallen_out_printer
Immerse it in warm-to hot water for a while or try using rubbing alcohol or similar Non-solvent based liquid.
Inspect the small rectangle shaped metal print head & surrounding copper track for dried ink , remove any with very gentle wiping taking care not to damage anything.
If it's beyond cleaning it will have to be replaced .Try ebay or the local print shop.
May 12, 2008 | Lexmark X1150 All-In-One InkJet Printer
Works great but won't print.
not good folks..check driver first. Also, would be helpful to have the operating system indicated for more effective help
Dec 11, 2007 | Lexmark X1150 All-In-One InkJet Printer
Black ink
Did you remove the tape from the cartridge when you installed it?
Has it ever printed black from this cartridge before?
You may need to wipe the cartridge with a moist paper towel at the place where the ink comes out. If there is dried up ink the nozzles could be clogged. Try running the Lexmark Solutions Center from the Windows Start menu (Start -> Programs -> Lexmark 1100 Series) and make sure the black ink level is good. You can also select "Clean Nozzles" in there and that may help.
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
