Hello, I have Targus AMW46EU model mouse.I'm using Win7 OS. Lately, I'm experiencing an issue where the mouse wheel page up/down is "jumping" up/down instead of the right direction. I've tried de-install the mouse driver and changed USB port (for the USB reciever) - unfurtunetly w/out success... Pls. advice how can I fix this issue, thx in adv.
  • 876 Answers
Please thoroughly clean your mouse and the surface that you use it on with a little windex on a paper towel or a wrung out windex wipe. These accumulate a lot of dust and oils easily and so does the surface of your desk or PC or where you are using it. Do not get the mouse wet.
After cleaning your mouse and surface, you might check your mouse settings this way:
>Start
>Control Panel
>Right click on Mouse ( or Mouse and pointing Devices)
>Open
>In this window you can check the settings for your mouse. Make any changes very slowly and see if it helps to slow down your mouse a bit.
Good Luck to you. A rating of this answer would be appreciated.
Posted on Dec 29, 2010
  • 384 Answers
It is a common problem .
you have to just disconnect and reconnect the mouse after restarting the system .
the problem will be solved .
My mouse targus AMU51US can not work because i do not have a driver , because when i bought it,in the pakage is not included the driver,
http://www.targus.com/us/content.aspx?page=downloads
o find the Manual or Driver for your product:
  • Use the Site search at the top-right corner of the site.
  • Visit the product page by selecting your model from the list.
    (NOTE: You may need to select the "Archive" tab).
  • If available, select "Drivers & Downloads" in the black box beneath the price.
  • Go to the "Driver" tab and select the appropriate driver for your device.
    NOTE: If no downloads are available for your model, the "Downloads" link will be hidden on the product page
Mar 13, 2011 | Targus AMU51US 3BTN USB OPTICAL ACCSLAPTOP...
Need driver for targus mouse amb04us win7
Targus Bluetooth Mouse Driver: Direct Download from Targus.com
Don't be mislead by the title of the file, the file covers any Targus Bluetooth Mini-Mouse.
Dec 07, 2010 | Targus AMB04US Mouse
Hi, I have targus usb to 232 serialcable , model
To use a pao88 on Win7 64bit you will need to have Win7 Ultimate, Professional or Enterprise edition AND your computers processor must support hardware virtualisation.
Dowload and install the latest version of XP Mode.
Install the cable in XP mode.
Turn on USB compatibility in XP mode.
Cable will now be accessable in Win7 64bit
I connected and ran a successfull diagnostic test on an old serial modem without issue.
Oct 27, 2010 | Targus (PA084U) Network Adapter
Looking for driver for Targus AMB40US mouse
Go to this site:
http://www.driverfiles.net/Input-Devices/Targus/page,level2,485,20,resultpage2.html
Apr 03, 2010 | Computers & Internet
No recognition by OS
Contact your provider and try to inquire whether what OS will the device run only. If the device comes with a container, try to read some instructions there on how to make it run and what particular OS it will run.
Feb 04, 2010 | Targus Wireless Remote Presenter Mouse
How do i install a targus mouse
Depending on your OS, just use the software provided and then place the batteries in the device and connect it as directed.
Sep 21, 2009 | Targus Wireless Optical Notebook Mouse...
Change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 07, 2009 | Targus PAWM001U Mouse
How to set up and use targus wireless computer mouse model#amw26
Under the mouse there should be a usb stick attached to the mouse which most likely should slide out from the mouse. It also appears that the plastic cover behind the two buttons (this cover has targus written on it) Should come off. After you remove the usb stick there might be a button somewhere on the bottom of the mouse that you should be able to press to get the battery cover to pop up. Then you should be able to pull up on the battery cover and remove it from the mouse. This mouse takes two AA batteries. Once the batteries are installed then plug the usb stick into any of the usb ports on the computer. The computer should recognize the drivers for this mouse (if you are using Windows 2000, XP, Vista, or Mac OS X [or higher]). If the drivers are not immediately recognized then restart your computer and the computer should then recognize the mouse. If this still does not happen then let me know. Also there is software that can be downloaded from the Targus website for the tilt wheel as it has some added capabilities that can be set using this software. The link for that software is here ------> http://www.targus.com/us/product_details.asp?sku=AMW26US
I hope this helps, and enjoy that mouse, it looks pretty nice!
Sep 20, 2008 | Computers & Internet
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
