Question about Toshiba TE2100 Notebook
TE2100 ASKING ME PASSWORD AT POWER ON - Toshiba TE2100 Notebook
    Guru:
  • 679 Answers
Hi
That password is a system password for your computer (setup password). you need to call toshiba to reset the password and they will give you a code to reset it.
contact numbers http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_contact
Posted on Dec 29, 2010
  • 516 Answers
If your notebook asking you a password while you turn it on, probably someone is set your basic input output system(bios) configured to prompt for a password. There are two ways to clear your systems password 1. is you have to guess for the password 2. you have to clear the cmos or bios settings by removing your cmos battery from your motherboard for about 10 seconds. Then put it back again then on your computer. That's all have a nice day!
3 Suggested Answers
  • 27 Answers
SOURCE: power on password for toshiba TE2100 laptop
Is this before the system gets into windows or is this a Windows Password? There are two Types of Passwords, The normal Windows one, and A BIOS system that will not allow you onto the System at all. There are two ways of fixing a BIOS password, 1). (and not all that common) There is a Master BIOS password that will reset all other passwords, This will take some research on the internet to find, But If you can find this, It will fix the BIOS password in no-time. 2). Remove the CMOS battery FOR 30 Seconds to 1 Minute. This may be a bit more difficult on a Laptop, But if you cannot get to it, Bring it into a Store, Most people will do this for little to no charge. Removing this Will reset the BIOS to default, So make sure you copy all the Settings so you can put them back to normal Before doing this.
Now if this is a Windows Password, you have no choice but to bring this in, Most Stores do have programs that Can Change the .SAM file. This isnt easy to do, So I would let a Professional do so
Jamzie
Posted on May 29, 2008
rubydu
  • 102 Answers
SOURCE: My TE2100 now asks for a HDD password on powerup.
there is virus attach on you hdd
changing of hdd is only solution
Posted on Jul 27, 2009
I can't clear the bios password on Toshiba Te 2100. Have removed the RTC Battery. Pse Help
Toshiba BIOS passwords cannot be removed by taking out the BIOS battery. You need to construct a piece of hardware.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.
Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Feb 26, 2010 | Toshiba TE2100 Notebook
Jul 27, 2009 | Toshiba TE2100 Notebook
Toshiba TE2100, Sreen flashes rapidly on and off, If I tap it on the side, it stops flashing, bu intermitently starts again. Seems lide aloose connection in the wiring to screen, as computer will still...
Sounds like you are correct about the loose connection. There is a thin ribbon cable that powers the monitor.
You will have to download instructions for taking your laptop apart, but once you do, simply reseat the ribbon cable. That should fix it! Good Luck.
Apr 07, 2009 | Toshiba TE2100 Notebook
Start up Fault
this is n othing but your boot password...........try any of your password you would have mistakenly type or only one alternative is left if oyur lapyop motherboard is having a flat battery if this is removed and placed again the boot password will be diable........hope this will halp you...............sameeraryan
Dec 18, 2008 | Toshiba TE2100 Notebook
Computer flashes light sequence when powered on but does not work at all.
Its the battery which is gone bad. It usually has a small chip infront of it and when it gets bad, then the power microprocessor detects it as a fulty battery and keeps the LED labelled battery below it blinking at 0.5 secs intervals. I still had the same problems and when i replaced the battery, then it was back online. If you want the POST technicals then google the following "Toshiba TE2100 blinking lights" Thats what i did
Jun 19, 2008 | Toshiba TE2100 Notebook
Power on password for toshiba TE2100 laptop
Jamzie
May 29, 2008 | Toshiba Satellite M30 Notebook
TE2100 FLASHING SCREEN
Hi all,
This problem happened to me also but luckily I fixed it.
1) Check to see if you still have the screen displaying something. it might be faint as the back light may not be on.
2) If you can still see something there then it's either the backlight tube or the inverter.
3) Out of the 2 it's most probably the inverter which powers the backlight tube.
I did it for my laptop and it works a treat. Good luck
Mar 29, 2008 | Toshiba TE2100 Notebook
Malfunction from connection PCB Power card on the motherboard.
dear dirk
for your solution i think you can visit this site
http://www.notebookrepairguide.com/
to make your vision clear and cheers
oke
thx
cropp
Mar 16, 2008 | Toshiba TE2100 Notebook
Toshiba TE2100 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
