Question about Mitsubishi VS-6047 60" Rear Projection Television
Television with no picture
My wife and I were at home 2 weeks ago when a bad storm came through our area and knocked the power out at our home. When the power was restored to our home, we heard a buzzing sound coming from our television.
After that day we have had no picture on the television, just the sound. When we hit the side of the television, then picture works for a short time, but then it goes blank again. We took a picture of the parts that look like they might be causing the problem. The only reason I say that is because when I tap on this part, the picture works fine. I would like to know if it is easy to order and easy to replace?
  • Jaime Hernandez May 11, 2010
    Could you post the picture to be able to give you more instructions on how to approach the repair?
  • 616 Answers
Just have someone resolder the area where you have found the problem
Posted on Mar 27, 2010
Replace the deflection board. Sounds like the vertical deflection was knocked out thats why you still have sound. You can get replacement deflection boards from
Aug 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound no picture This Tv has been in a model home for 3 years unused. Home was sold 3 weeks ago and this problem showed up. This tv wa $3800
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
No sound
Did you have storms go through your area and lightning strikes or power surges? We did a few weeks ago and I have very raspy sound but perfect picture...
Mar 04, 2008 | Sony DAV-S300 System
Sony KV32hs510 - Won't come on flashing light - 6 or 7 times
hi there, you have the hardware prob., at the power supply section., test the bleeder resistor which is 100 kilo ohms or higher, do some check up and test. ty
Feb 16, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
