Question about Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw
I have a 2250 Poulan. The fuel lines have been removed. Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer's suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to? Is there a fix for bar oil running out of the saw all the time until the tank is empty? Can the oil rate be adjusted?
    Sergeant:
    Champion:
  • 226 Answers
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Posted on Dec 29, 2010
Fuel line replacement poulan 2250
cut one end of the new hose down to 1/3 about a 1/2'' long slide a wire threw the tank and out of the gas cap opening slide the new hose trimmed end and pull the wire and hose back til the trimmed end sticks out pull the hole threw connect the filter to the end and pull into place trim and connect to the carb the return side do the same way just without the filter
Aug 21, 2012 | Poulan Garden
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Jul 13, 2010 | Poulan 14" Chainsaw
Poulan P3400 Chainsaw Fuel Line Routing
If the saw has a primer bulb, then you require one line from it's output out to the tank return. Another line runs from the carburetor outlet to the primer inlet. Make sure that you use original rubber lines, not plastic replacements. The primer ports are found by trial and error--hook the filtered line directly to one primer port and leave the other port open. If the bulb is in good condition, and correctly connected to fuel, the bulb should fill with fuel after several pumps. If nothing, reverse the port connection at the primer--and pump test again. One of these two connections should allow pumping to occur. When you get pumping, install the tank return line to the empty primer port. Remove the filtered line from the primer and install on the carburetor. A new piece of line runs from the now empty primer port and connects to the output port on the carburetor. If the carburetor lines are correct, you should be able to pump fuel through the carburetor body and out to the primer bulb. If nothing happens, you may need to swap the carburetor lines, and you will likely need to service the carburetor. Hope this helps!
May 25, 2010 | Garden
Fuel line routing
A typical fuel system and a couple of suggestions follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
Fuel line diagram for 358.352160 don't know how to route the fuel lines correctly. Have 2 sizes
It is most likely a Poulan almost all are. The IPL is the only manufacturer supplied fuel system detail, it lists components, part numbers and very little routing detail. and is usually spread over multiple illustrations.
Poulan.com
I think you'll find the short video, a few notes and a typical system most helpful. Any local saw shop can provide replacement hose.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Nov 19, 2009 | Garden
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Poulan sm132 fuel line routing
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Aug 27, 2009 | Garden
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Logo
484 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
