Question about Sony Handycam DCR-DVD108 DVD Camcorder
Screen goes white ,some times works, touch screen is going out too. 1 year old .taken good care of.
  • 1,557 Answers
There is too much power going to your screen try turning down the back light have a look in your manual for this option
Posted on Dec 29, 2010
White screen after about 20 minutes of operation
key words above, (change(d) PC) did you mean you changed out the PC, and it fails, I will guess yes) as in past tense?
old old , 1710s, most are now dead, you know that right?
all have CCFL tubes in it.(problematic for sure)
and had a sleep mode inside, (problem 2) sure.
so with PC turned on, the push the menu key
and turn off the sleep timer, keep it off for ever.
it is not compatible with NEWER PCs at all.
the Monitor is bad,
if cable and pc are ok, the monitor is bad.
you proved that, if change = changed. above.
like this. (GO LED !) avoid all monitors older than year 2010 !
https://www.walmart.com/ip/Asus-LCD-VS197D-P-LED-Backlight-18-5inch-Wide-1336x768-50000000-1-5ms-VGA-Retail/20701019
Nov 06, 2017 | HP L1710 LCD Monitor
Touch screen working but it's not recognizing finger to chang
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Mar 08, 2011 | Ricoh Aficio 3025P Black and White Copier
I have a samsung touch screen phone. its 1 year old .the screen on the left side isn't working . if i touch the button on the left the buttons in the middle work
You have problem with the circuit beneath the touch screen and it need to be taken to nearest Samsung technical care centre or any technical mechanic / expert who can repair this fault
Sep 07, 2010 | Cell Phones
Why is my Dell Latitude D620 laptop screen turning white?
You'll have to live with it. It's taken damage, it's not repairable, it's only replaceable. My Latitude screen was replaced after only 2 1/2 years.
Nov 02, 2009 | Dell Latitude D620 Notebook
Internal screen failing
im afraid its the phone itself thats the problem. no motorola V3 ive known has lasted more than a 9 months, and ive known a lot of them. they just disintegrate. no matter how much you try to repair it, it will be a false economy, both time and money. My advice is to discard it and get a new phone, before it drives you mad. If you dont care what i think about the matter, a solution to this problem is to reinstall the firmware, there are plenty of websites dedicated to motorola flashing, just google "Motorola V3" or try www.ipmart-forum.com
Jun 10, 2009 | Motorola Mobility RAZR V3
White screen
Any answers to this,... I have had mine for 3 weeks and now can't use it!!! Due to the white screen HELP!!
Jun 15, 2008 | Nokia e65 Cellular Phone
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Something wrong with my lcd screen
As a quick test I would try connecting the monitor to another PC to make sure the problem follows the monitor. If it does then the likely cause is a circuit board or possibly a poor connection inside the monitor. Since working on this would require opening the monitor case and voiding your 1 year warranty I would recommend you contact Samsung support for a warranty replacement as soon as possible. When you do make sure you mention the problem goes with the monitor and any other troubleshooting steps you have taken. Also the replacement they send will itself be something that was returned and fixed.The only warranty you will get will be whatever is left of your original year so definitely get this taken care of as soon as possible.
Jul 11, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Can see screen for one second
I had mine for almost 3 years and last month ran into the same problem and i take good care of it. I turn it on it stays on for a 1-3 sec and goes black. can't figure out what it is
Apr 19, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
101 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
