Have a whirlpool WFS1276AW washing machine and it wont go to a fast spin.on any cycle. have replaced motor and start selonoid, only board left. any ideas.Also pulled out timer then when put back in only get lights not start. not sure where red loop wire goes. thanks
  • 1294 Answers
SOURCE: whirlpool awm5125/4 washing machine
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
Posted on Apr 18, 2007
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
sdmc73
  • 121 Answers
SOURCE: Whirlpool Washing Machine does not spin in certain cycles
yes the timer can cause that but it could be the moter but more likely the timer
Posted on Nov 29, 2008
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
  • 3230 Answers
SOURCE: Replace Timer Assembly on GE WJRR1470E1WW Washing Machine
Servicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
In the next section, we will examine two of the most crucial elements of a washing machine -- the water inlet valves and the agitator.
Posted on May 17, 2009
Ultimate Care 2 top load. Why won't it spin fast enough?
could be a failing start run capacitor for the motor or a problem in the controller board as some washers spin slow while introducing water into the tub or initially on the rinse cycle
have a technician check it out
Sep 12, 2015 | Whirlpool Washing Machines
My zanussi zwg6141p wont spin and cut out during wash?
replace the carbon motor brushes and retry if it wont spin usually the water isnt taken out fast enought to satisfy the vaccume switch so its the pump the switch or an air lock
so empty the machine totally and expell all water from all hozes and check the waiste is aok for flow no jams your left with either the pump motor issues bits of b.a wires or the main motor brushes
Mar 05, 2015 | Zanussi Washing Machines
Washing wont fast spin and empty
Possible that the control has failed and so does not instruct the main board to control the spin and continue with the drain.
Need to check the voltage on the controller and the drain pump at the cycle to confirm this case.
Jul 25, 2012 | Whirlpool Washing Machines
Spin Cycle
I just replaced my second motor control board because of the same problem. Mine starts to spin but never reaches speed and stops, then it repeats. It can do this for hours. I think we are overloading the machine washing area rugs. The fuses are OK on both failed boards and nothing is burned and all caps look normal. At $150 a pop, I would rather replace some components if I knew which ones. For a quick fix, the new board worked for me.
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Fridgidaire front loader wont go thru spin cycle
This sounds like it is either part of the motor that is burnt out, or a fault on the control board that controls the fast spin speed.
The motors have a number of coils, so a fault with one will cause problems at just one speed.
The power transistors on the control board can also fail - leaving one speed dead, so either of these faults may be the reason yours is not working.
#1 - Check all motor coils
#2 - Check operation of output Power transistors.
Above tests should be performed by competent engineer only.
There is also another fault concerned with an unballanced load - If it spins a few times and bounces a lot, then it will abort the spin cycle. This is usually the fault of the dampers - which are a cheap replacement.
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
My washing is still very wet at the end of a wash cycle and when I try to put the washer on a short spin cycle nothing happens. the drum is definitely turning through the wash cycle but not turning very...
Could be an issue with the timer. For the typical later model Whirlpool/Kenmore direct drive washer the motor always turns in the same direction while agitage and spin go in opposite directions. There is a transmission/gear box which allows whis to work. The timer is supposed to pause for about 10 seconds just before the spin cycle to allow the motor to stop and then start again when the gears are set to spin mode. A bad timer (which is a common problem) may not be allowing this reset and the washer won't spin all of the time although it may agitate and may spin some of the time.
Tell-tale sign of a bad timer is a small burn mark near one of the connectors. You may have to remove the timer to see this and even then look very closely.
A new replacement Whirlpool timer will run you between $100-150 for the part.
Hope this helps.
bd.
Sep 16, 2008 | Whirlpool Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
