Question about Lakewood Oil-Filled Electric Radiator Heater
Hi! My name is Nicole. I own a Lakewood model#5500. It has been working fine up till now. The problem is that when you turn the 600w, 900w, or both switches on, no heat is produced through the coils. There seem to be oil in the heater. The switch lights do come on. I am wondering what could be wrong with it and I hope you can tell me what the issue could be. I am hoping that I do not need to purchase another one.
  • 11,800 Answers
If the switch lights do come on when the switches are activated then the only parts that might be failed are the resistors that heat the oil or the thermostat. You will have to remove the cover on the panel (held in there with clips that you must pry open) and, using a basic multimeter set on resistance, check the continuity of the resistors. If they are ok then the thermostat has failed and it's no longer passing the current. You can bypass it but you must make sure the radiator doesn't overheats - from now on you will have to use it only supervised. Or you could visit several repair shops and find out if they have replacement ones - it will cost you around $60 to replace it.
Posted on Dec 29, 2010
I have a Lakewood convection air heater model 515-T. I need a leg and 3 screws. Is that possible., Thanks
Well, they don't seem to sell parts for these. So the best bet would be to try ebay or craigs list, for a used heater for parts.
Mar 24, 2011 | Lakewood (5500) Oil Filled Radiator Heater
My Lakewood heater turns on but will not produce heat. Any ideas as to what is wrong????
Same symptom on my oil-filled Lakewood model 5500. Used an ohmmeter to check it out and found that 1) the thermostat is defective and potentially a fire hazard due to intermittent operation. 2) Then I learned of reports about some Lakewood oil-filled heaters squirting hot oil and injuring people, and 3) the manufacturer subsequently going out of business. Three strikes and you're out.
I cut off my heater's power cord and threw the whole thing away, and recommend others to do the same.
Feb 07, 2011 | Lakewood Oil-Filled Electric Radiator...
The rolling feet are missing. Any idea how to find replacements
I have a Lakewood 7096 heater. We purchased it used and got 8 to 10 years of service out of it. It was never heavily used while in our possession, just to heat the bathroom for showers.
The 900W switch quit working after used it and showered Sunday. The 600W switch still works fine, but the unit doesn't produce much heat at any speed.
After looking at various posts on fixya today, I decided to pull the pair of switches out. The 900W switch is burnt. The wire attaching to the 900W switch is burnt and bare!!! I don't know what happened. I would be scared to use it again, even if I replaced the switches and the bare wire. I don't know if it's even safe to use the 600W setting.
Anyway, I purchased a sunbeam radiator heater this morning. The ol Lakewood has the wheels you are missing. If were to come to an agreement on price, I would be happy to ship them to you. They are in good shape, just a little squeeky, which a little oil would fix.
Jan 17, 2011 | Lakewood Oil-Filled Electric Radiator...
How can I find our what the controls mean, the dots on the 6500????
thegreyone_0.jpg I could not easily find an instruction sheet, but I believe that the top knob is the thermostat... rotate it clockwise for higher temperatures and counter-clockwise to lower the temperature. The lower knob controls the number of heating elements. The first dot/dash if for the 600W element only, the second longer dot/dash is for the 900W element only; and the longest dot/dash is to select both the heating elements giving 1500W total output power.
I hope this helps...
/denis
Dec 10, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Need a thermal cutoff for our Lakewood 5500
We have these heaters and haven't had a fuse fail yet. I think it's because after the first time I got that crackling sound after moving it while it was on, I stopped doing that, and only move it with the power off, and wait two minutes before restarting it, so the oil can resettle.
However, the thermostats are now failing. Anyone know if this part is available?
Apr 10, 2010 | Lakewood (5500) Oil Filled Radiator Heater
I have 2 Lakewood 5500 oilfilled radiator heaters. The inline fuse has gone out in both of them. Where can I find this fuse?
Hi ladybug75846,
I have the same problem. My husband checked the continuity and found out the thermistor is the problem. The thermistor is stamped S.W.C. SW-122. If you find a source for these, would you kindly post it. Thanks!
Feb 26, 2010 | Lakewood (5500) Oil Filled Radiator Heater
It will not turn on.
give this s try
unplug it wait for 5 min. then plug back in
Feb 11, 2009 | Lakewood (5500) Oil Filled Radiator Heater
Lakewood Oil-Filled Electric Radiator Heater Logo
Top Lakewood Heating & Cooling Experts
Mack Baxter
Paul Carew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
