Question about Andis T-Outliner Hair Trimmer
What size are by blade screws. - Andis T-Outliner Hair Trimmer
  • 1,557 Answers
3/.15 mm
Posted on Dec 29, 2010
How do i find screws for mounting brackets?
Contact the manufacturer for the proper screw size. Just give them the Model number and they'll provide you the correct screw size. They may even just send them to you for free or for a nominal charge.
Sep 28, 2016 | Heritage (4FNW42PT1M) 42'' Ceiling Fan
What other makes of attachment will fit the MtD power unit?
I have used blades from Toro on my MTD mower, found them better then the what MTD gave me ,bit stronger and cheaper. Just be carefull, when you take the blades off,do keep the 2 screws that hold the blades in place, they have different sizes depending on what brand you have, blades can be swapped but the screws and bolts can not be changed with other types. For belts etc you can use any " generic " brand, size matters but brand is not a big difference, i used belts from 40$ and 100$ , no difference what so ever. To be honest , the cheaper one is still running after 2 seasons while the expensive one snapped after one season.
Apr 20, 2016 | Mtd Garden
Blade screw keeps turning when trying to replace blade
remove the power lead from the wall socket
put a screw driver in the teeth of the blade and use it as a stop against the guide
use the right size spanner and undo the blade retainer nut
Aug 21, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
How do you replace the fan blade on the ceiling
after you obtain a replacement blade, preferably of same size and weight for better balance than a blade of different stats that will make the fan move around like crazy when running, remove the screw the mount it to it's arm. these screw are accessed by getting into a position where you can reach the top side of the blade(the side facing the ceiling) and using a screwdriver to remove the screws. put new blade on replace the screws(you can use the same ones you just removed from it) then turn on the power and enjoy the breeze.
Feb 19, 2013 | Dryers
Husky thd750 wet saw changing blade
If this is the K750 cut off saw, then to change the blade you need to remove the 13mm fixing screw ( anti clockwise )if you cannot hold the old blade to remove the screw, insert a 6mm pin into the right hand belt cover, there is a hole to tale this, this will engage into the pulley and lock it, then remove the outer flange, the old disc will now come away, make sure the new disc has the same size centre as the old one, the size will be on the rating plate on the cutter guard.
Oct 29, 2011 | Garden
Size of screws to mount fan blades
mcdevito75 here, A large hardware store like Home Depot, Doody's should have a standard kit of screws for the fan blades of most newer ceiling fans.
Jul 27, 2010 | Heritage Hugger White Ceiling Fan
Locking screw for blade on reciprocating saw
Virtually every manufacturer has a different size thread for the locking (set) screw on their saw. Your best bet is to contact the manufacturer for a replacement.
Feb 11, 2010 | Garden
Neeed correct screw size for fan blades
go to the hardware and bring your orginal ones to buy exactly the correct size of screws theres a lot of screws being sold there.
Mar 21, 2009 | Heritage (4FNW42PT1M) 42'' Ceiling Fan
What size screwdriver is required to remove the screws on the braclet of a ladies accutron courchevel 26R28?
All screw heads in watch bracelets are usually 0.8mm - 1.30mm in diameter. In my experience screwdriver with the blade width of 1.00mm was good for unscrewing the bracelet screws in majority of cases. So, I would advise to buy a screwdriver with 1.00mm wide blade.
In case if you realize that the bracelet screws are a tiny bit smaller than your brand new screwdrivers blade - do not panic but use the sandpaper or any sharpening stone. Just a few strokes from both blade sides will reduce the width of the blade to the required size and you will be able unscrew the screws with ease.
In case if you brake the tip of the blade, use the same method as described above, just in this case reshape the blade. As the size of the blade is quite small, it is easy to do and takes very little time.
And,yes, the blade can be reshaped plenty of times, not just once or twice. In fact it can be reshaped and sharpened till you run out of metal.
Do not forget to rate, please.
Mar 12, 2009 | Watches
Security screws on bottom of coffeemaker
I took a small (cheap) slot screwdriver with a blade just wide enough to fit into the wide part of the screw. I then took a hacksaw to the center of the screwdriver blade. This works best if the hacksaw blade is fairly thick. The idea is to remove enough of the center of the screwdriver blade so that the screwdriver can be inserted into the screw allowing the hacked out area of the screwdriver blade to fit around the stupid center post of the screw. The screws on mine weren't that tight, so I could turn the screws without twisting the screwdriver blade.
Dec 08, 2007 | Krups Aroma Control 229 Coffee Maker
Andis T-Outliner Hair Trimmer Logo
77 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
