Repair manual for a Simpson enduro 701 7kg heavy duty washing mashine
ginko
  • 19396 Answers
SOURCE: machine over filling even when
When the machine is overfilling , it means that there is a problem with the inlet valve (valve not closing) or with the water level switch, that should turn off the valve when water reaches level.
See the suggestion from It's overfilling at repairclinic:
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Oct 06, 2008
SOURCE: i have a kenmore 80 heavy duty it will not spin washing machine
does it agitate?check your coupler.
Posted on Nov 14, 2008
  • 76 Answers
SOURCE: westinghouse heavy duty washer
Check this website out. It has a good questions and answers section. I would guess that it is the water inlet valve in the washer, but it could be a few different things.
http://www.repairclinic.com/0088_11_1.asp
I know of a different site that has good prices on parts. I have ordered from them numerous times. Let me know if you need that link.
Posted on Oct 04, 2008
docjohn174
  • 943 Answers
SOURCE: simpson enduro washing machine 701
HI thanks for the question. I would replace the water valve . this is a sign of a faulty valve. thanks . rate my answer please
Posted on Oct 07, 2008
localwonder
  • 6784 Answers
SOURCE: the top load heavy duty mashine wont wash
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cuase this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Posted on Aug 11, 2009
My simpson aquapulse 513 5kg heavy duty machine, spins washing into balls and then stops, what must I do to repair this
You will probably find the agitator is spinning but steel bowl isn't. Either brake release is not working or clutch problem. Not an easy fix. Best to get someone out to repair it.
Nov 12, 2016 | Simpson Washing Machines
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson enduro 501 wont agitate. Everything except the Wash cycle works...
check the cam dogs in agitator and check the water pressure switch with a meter it controls when machine goes into wash cycle
Feb 04, 2015 | Simpson Washing Machines
Brake band for Simpson Genesis 505 heavy duty washing machine
www.searspartsdirect.com or www.applianceparts.com. If the brake is internal with the gearbox, chances are the only way to replace the brake is with a new/rebuilt gearcase.
May 10, 2012 | Simpson Washing Machines
Washing Machines Logo
1,154 people viewed this question
Top Washing Machines Experts
