Question about Sony CPD Computers & Internet
Hi there I hace a Sony CPD200ES monitor that had the video input cable cut off and I don"t have the cutoff part any more. I have a cable that I removed from a junk monitor (a Datatrain DC509) but not all of the wires have the same colour code, Actually the Sony has a couple more wires than the Datatrain cable has. I Need to know which colour wires on the Sony went to which pins on the (missing) connector. Thanks in advance, Bob C
jemmyrash
  • 180 Answers
SOURCE: Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Posted on Apr 19, 2008
SOURCE: pioneer cdx-p24s wiring
**** - have you had an answer yet?
I've got one of those too - let me know if you still need the info.
Grtz,
Rick
Posted on May 09, 2008
SOURCE: VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Posted on Dec 24, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
randy320sgi
  • 121 Answers
SOURCE: I have a Sony monitor model GDM 20 E01 defected ,need another
maruan, That's was a nice monitor,, yes there are some monitors that still use the RGB BNC, but your computer still has a standard monitor connection or DVI from the video card, a new monitor will come with a cable.  Prices are down now on LCD's - the all-purpose LCD that are PC and TV compatible have those connections but they aren't as nice. randy320sgi
Posted on Jan 09, 2009
Only showing half screen
sony cpd200es bottam vertical fold
Sep 17, 2013 | Computers & Internet
Hp elite 7100 dvi no signal
If your monitor has both VGA and DVI video inputs and does not auto-detect the video inputs then you need to go into the monitor's Menu and select the DVI video input.
Mar 28, 2013 | Computers & Internet
Monitor not even powering up? Is it a cable or a defective monitor or am I just missing the "ON" button. I really don't want to drag this back to the store 30 miles away.
Most modern monitors have DVI and VGA input; it could be a setting issue such as having your monitor select the correct input. As long as your computer is on, the monitor should automatically come out of standby mode and fully power up (provided it's not on sleep mode or screen saver of course).
Jul 20, 2011 | Computers & Internet
The screen is showing "No
check input output pins of tv or try to scan
May 04, 2011 | LG.Philips LCD LP150X05A2 Monitor
Hi,I have a LCD monitor Philips 19 inch Black. From time tot time,appear one error... NO VIDEO INPUT , and then is made black and appear "Entering sleeping mode" . What I must do? Or for where...
Check that the Video cable (VGA or DVI) is not damaged, if you move it does the screen go on and off?
If not then the circuit board inside the screen is faulty and needs reparing
Apr 05, 2011 | Philips 170S4FG 17" LCD Monitor
I run a PC with the newest sandy bridge hardware and a Msi GTx 560 Twin Frozr II video card (dual Dvi-I input and a mini-hdmi input). I also have a BenQ G2222 monitor (one VGA input and one DVI-D input),...
The problem might be with your ram. Try taking it out and putting it back in. You might also have a problem with the video card. Make sure it is secure and screwed in.
Mar 19, 2011 | Computers & Internet
When the monitor cable disconnected you get a "check cable connection message. With the cable connected you get a "no input error" and the monitor instantly gives a "going to sleep...
There's a problem with the video out. I would suggest trying to use a video card for video. You could also try resetting the cmos but I doubt it will fix things...more than likely you've got an issue with the motherboard's onboard GPU.
Mar 18, 2011 | ASUS (M2NGREEN) Motherboard
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
Audio cuts out on my reciever
Try selecting any option for decoding priority from "auto" to "pcm."
May 09, 2009 | Audio Players & Recorders
How to connect a sony monitor no tv tuner to a cable box
It's unlikely that you'll be able to use a computer monitor as a television.
Cable boxes have specific outputs, and computer monitors have specific inputs. They generally don't align with one another.
However, your monitor may have VGA inputs on it, and your cable box may have a VGA output (though unlikely).
If you can provide the model number of your cable box, and your monitor, I'll be able to help you more.
Mar 17, 2009 | Denon AVR-886 Receiver
Computers & Internet Logo
79 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
