Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
My samsung printer is showing cartrdage problem.even new cartdage,someone told me that memory need to be refresh to correct this problem.where i will find the software ?
  • 3 Answers
Please video you tube Samsung SCX-4300 error
Posted on Dec 29, 2010
Hi, I charge my samsung tablet, may or may not use it. the battery icon does not show correctly. some times it says that "charge the battery" but i leave it aside and after for example one hour i check the...
You are likely running an old version of the firmware / ROM. See if Samsung has a new version, or if you are comfortable with rooting visit XDA Developers forums to learn how to get a newer version with more up to date power management and battery conditioning updates.
Dec 04, 2013 | Samsung Galaxy Tab Tablet PC
My Samsung SCX4623F printer is telling me that my new printer catride is incompatible. What do i do
Dear
Make sure the toner you purchased is genuine.
Also make sure that the printer region and the toner region it matches( the samsung manufacture the detection chips of the toner and printer region wise)Contact Samsung call center and ask them for how to clear the memory and select the correct country of your location.
If you have refilled the toner it may not work properly. you need to contact refiller to get compatible chip.
Jan 17, 2013 | Samsung SCX4623F Laser All-in-One Printer
I have got my samsung 4300 toner refilled,and the display shows toner exhausted .the person who got my toner recharged told me that samsung 4300 printer has some inbuilt chip,which needs to be changed...
Hi
The person refilling your toner needs to install the correct chip onto the toner cartridge. The chip stores the number of pages printer by that cartridge and is unique to each model printer, therefore an incorrect chip will not work. Good luck with that
Oct 06, 2010 | Samsung SCX-4300 Monochrome Laser...
Printer problem
how to shot the printer chip of scx4300 for refresh the tonner for printing
Feb 18, 2010 | Samsung SCX-4300 Monochrome Laser...
Paper jam
Probley not but i think you may be able to extend you warantee if they will let you so they can fix the senser or what ever is casing it to do that.
Jul 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Cannot print on new Macbook with Leopard Mac OS - need driver
I just upgraded to snow leopard and my previous driver was erased, so I did some digging around and found the right driver (it is not included even in the most recent GutenPrint software).
Look at the Global Samsung website - the US Samsung site does not support MacOS drivers.
http://www.samsung.com/download/FileView.aspx?cttfileid=213919&type=Printer&typecode=15&subtype=Laser+Printer&subtypecode=1501&model=ML-1430&filetype=DR&language=
Your OS should ask to install Rosetta to read the file (Zip), but then the install is quick and easy. The printer driver immediately showed up in the printer>setup>driver menu. Prints without a hitch.
Haven't booted my laptop into 64bit kernel, so I don't know if the driver is 64bit compatible - I expect not. Hope this helps.
May 31, 2009 | Samsung ML 1430 Laser Printer
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Paper jam
THE PAPER IS INSIDE BETWEEN THE ROLLERS AND YOU WILL HAVE TO REMOVE THE COVERS OR PAY SOMEONE TO FIX IT FOR YOU.
AS CHEAP A NEW PRINTERS ARE WITH INK AS HIGH AS THEY ARE, YOU CAN BUY A PRINTER CHEAP AT WALMAT,
LAST WEEK WE BOUGHT A NEW CANON FOR 29.99, IF YOU DONTS WANT TO HASSLE WITH IT THAN BUY A NEW PRINTER
Mar 31, 2009 | HP Officejet 4315v All-In-One InkJet...
Memory card Samsung Nv3
This is a common problem and I had the same issue. Samsung only guarantees that a 1GB external memory card will work. If you look at the user manual on page 77. I just used a 1GB memory card instead and it worked fine.
I am not saying that no memory cards greater than 1GB will work but I would try to find someone that has used the brand and size and knows that it will work.
Sep 08, 2008 | Samsung NV3 Digital Camera
Toner error
hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
