Question about Compaq Computers & Internet
System having an error mess of no hardisk - Compaq Computers & Internet
    Guru:
  • 679 Answers
Its either you need a new SATA cable for your hard drive (busted hard drive cable ) or your Hard drive needs replacement
Posted on Dec 29, 2010
Trying to reboot my PC
There is some posibilities that generate that error, this is some of them :
1. Your Hardisk error, your bootable psrtition is corrupt or something, can be caused by not properly shutdown, repair OS with CD recovery may help you.
2. Your hardisk is fine, but you attached new non bootable hardisk, if yes, you may need to change boot order on bios.
3. You attached USB FLASHDISK, or USB Hardisk, try to remove that and rebot your komputer.
Oct 29, 2017 | Computers & Internet
Hardisk 1 quick (303)
Sounds like a faulty hdd. Error 303 means bad communication.
Feb 21, 2014 | Computers & Internet
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
I have an acer apire 5515 and everytime i turn it on a black screen pops up saying that an disk read error has occured; how do i get my computer back working
you have problem with the hardisk, either bad sector or broken partition. Using the hardisk utility will solve this problem, but if not familiar with this tool will totally damage the hardisk
Apr 10, 2010 | Computers & Internet
Hardisk error, how can solv my problem?
try reloading your operating system first. if it still has an error, then its the drive itself that needs to be replaced nd not just the software part which is the operating system.
Apr 03, 2010 | HP Compaq nx7010 Notebook
My Dell Desktop cannot start in Safe Mode
hi there,
you mention you have change your hardisk,you have to check if your hardisk was configure in cmos and bios set up, first whaen you start your computer press F2 then bios set up appear,check your device if
was connected on your system.on main menu check your ram if it was connectd,then press arrow right to advanced menu check your hardisk from IDE configuration if both hardisk and memory was installed or cofigured by your system.go to boot menu to set your device, on boot menu,scroll it from boot device priority
if you assure there is windows installed already on your hardisk,priority your hardisk,second your cd room,third floopy etc.press F10 to save and restart your computer,If no sytem was appears you must reinstalled your windows but you should change again
the boot set by priority the cd room instead of hardisk in order to put windows on your computer.press F10 again to save and restart your computer
to install your windows
insert windows cd on cd room
wait to configure your computer by the cd windows
then ff the windows installation procedure
until windows installation was finish.have a nice day don't forget to rate me please.thank you
Feb 21, 2010 | Dell Dimension 3100 PC Desktop
When formating progress error code "windows no disk" but the hardisk is still in good condition,
hi! system disk error,no disk on windows,check hard disk from your set up if your hard disk was configured by your computer, restart your compurter press F2 or delete depend how you start your cmos and bios set up,you can see this on left down corner of your windows when starting your computer,if it was there, this might have loosen connection of your hardisk i.d.e cable switch off your computer,disconnect your i.d.e cable just to refresh connection or replace if you have a new one,connect again make it sure it was properly connected,resstart your computer check if your windows will appear.if not reinstalling your windows might solve your problem you mention that your hardisk was good. ....regards
Mar 25, 2009 | Acer Aspire RC900 (91.PJB6P.UE7) PC...
My computer freez and go blank after formatting the computer
Greetings,
There is no problem with your computer as a whole it is your hardisk that has a problem, It cannot continue installing the system files because an error occur in your hardisk. Format your hardisk with other computer.
If you have an extra hardisk much better.
Thanks
Nov 12, 2008 | IBM NetVista PC Desktop
Disk boot error
Maybe your Hardisk drive is faulty already, try replacing the hardisk drive, bad thing, you also need to re-install all the softwares you needed.
-mrsolution
Jun 12, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
