SOURCE: How old?
Check the metal tag inside inside the fridge, not the paper sticker in the freezer. My Hotpoint has both but only the tag in the fridge has the full model number. Correct model number tag should also have the serial number listed on the tag. Also some models will have a tag on the back so check there too.
Since Hotpoint is made by GE you may also want to look on GE website: http://www.geappliances.com/service_and_support/
On their site I found a luink to a PDF scanned file of the user guide for CTF19 models. http://genet.geappliances.com/DocSearch/pdf/39-6193.PDF
Last page of the PDF lower left is dated 9/82 this couls be close to the year of your unit.
Good luck.
SOURCE: maytag fridge defrost timer location
its not a timer , but an adaptive defrost control board, in the upper rigth hand side of refrig compartment, atop the control housing heres the part number 61005988.
check this site ==> http://www.fixya.com/support/t1330051-defrost_timer
Good luck,
Tony Ip
SOURCE: Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
SOURCE: Welbuilt Refridgerator (old) - Which way is coldest - 0 or 6?
Most controls work with the highest number being the coldest. Keep in mind that once you adjust that setting you should allow 24 hr for the refrigerator to "equalize" to it new set temp. Hope this helps
