Question about Panasonic PANAFAX UF-6000 Fax
Continuous Fast Busy Signal
I have a Panasonic Panafax UF-6000 that will not send or receive. There is a continuous busy signal. The telephone line works, because it has been successfully used to connect to remote locations and an analog telephone was connected (incoming/outgoing call successful). Checked the manual Hi & Low for clearing the memory and no instructions are available. Help!
  • 284 Answers
You might need to do a all job clear. leave me and email address and i will gladly help
Posted on Sep 22, 2008
  • 2,072 Answers
Your modem/fax board is most likely bad. there is a relay on that board that has probably failed. It is stuck. I doubt it can be made to work. those are really small relays on those boards.
Posted on Jul 24, 2008
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
I have a cordless phone that every time I try to make a phone call the busy signal comes over my phone how can I correct this problem
Are you getting a continuous busy signal, or just five or six quick beeps then a dial tone?
If the latter, you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
If the former, please add a comment to this question and specify the make and model of your phone.
Jan 26, 2015 | Motorola Mobility MD761 Cordless Phone
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
Incoming faxes are showing busy on the sender's end.
TAM is the setting for answering machine. Set it to fax. Not sure how on those ones.
Mar 31, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Switching fax machine from telephone to fax
Make sure you are NOT plugged into the port that has a picture of a telephone it.
Function 74
choose fax
unplug the power cord for 10 seconds.
Dec 17, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Panafax UF-6000 can send but not receive
Yes, especially if they were active.
Do they show Code 21?
Factory reset them.
Unplug the power cord from the back of the machine
While holding down the ENERGY SAVER key, plug in the power cord.
Scroll down to SHIPMENT SET
press SET
press 2
wait for machine to reboot
Oct 16, 2008 | Panasonic PANAFAX UF-6000 Fax
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
Incomplete info code 634 how to fix
That codes says:
"Redial count over with no response
or busy tone was not detected.
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Jan 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic PANAFAX UF-6000 Fax Logo
269 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
