Question about GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven - f3 error
HEY,
Looks like key pad shorted for this GE microwave we are using getting a F3 and light is on but.... on unplugging and replugging does not solve the problem
Can you guys help me replacing the key pad ? and how much does it cost ?
Thanks
Anil
  • GE Master
  • 9,098 Answers
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 08, 2008
GE JVM1440SH001 f3 error
see the commentaries and repair:
F3--Shorted key panel(touch pad), will occur if a shorted key panel is detected continuously over 60 seconds.
test the following:
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jul 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
F3 error
HI, the Key panel (touch pad) is shorted.
Jun 16, 2009 | GE Advantium SCA1001SS Convection /...
Spacemaker Microwave Oven
F3 means shorted key panel. You get prompted with F3 error if a short on key panel is detected for over 60 seconds.
Test key panel wiring and eventually replace key panel.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | GE Spacemaker JVM1750 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,765 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
