Question about Behringer Digital Multi-fx Fx600 Pedal Make Offer
Mine won't turn on! I've had it for 3 years and I haven't used it for a while but I tried using it today and it simply won't turn on.
  • Behringer Master
  • 5,603 Answers
Change the battery or check your power adapter.
Posted on Dec 29, 2010
My Zoom R16 wont turn on
Hi , i have the same problem, did you fix the problem already ?
Jan 06, 2013 | Samson Technology Zoom R16 Recorder /...
How to do transposition on Roland E-70 Intelligent Synthesizer from C to B
I don't know if you still need this information but here's a button by button guide that I've done. I've got an E-70 myself. Now if I can only find that **** internal battery that stores all my sounds I'd be laughing.
Press Menu (the button on the right underneath the light-up display), make sure the arrows are highlighted around the 'Param' setting and if not, turn the jog dial anti-clockwise to get the arrows there. Press Enter and then on next screen press Enter 5 times to see the Transpose display flash and use the jog dial to change from -11 semitones to +11 semitones and press Enter or backup to come out of this screen. Now, whenever you press the Transpose button (the grey button on the bottom right-5th button in from the right), the keyboard will automatically change. You can store different sounds in different keys, so for example I used to play Knocking On Heaven's Door and had this lovely riff when I played in G but it didn't sound the same if I played it in A so I transposed it to play and performed live in A while playing it in G. As long as you what presets you use for different songs, it's quite easy to get used to.
If you haven't had a response or sorted it out yet, I hope this helps.
Kind regards
Steve
Mar 11, 2012 | Music
Very low volume from mic input even with Gain and Master turned full on
You haven't told us what type mic you are using. If you are trying to use a condensr mic with this, you will need a preamp that supplies Phantom power to the mic. You haven't told us what cable you are using. Do check that you aren't using a condenser mic as there will be virtually no volume.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
My P85 simply won't turn on. I have tried two different adaptors. Neither work yet they are functioning with other keys. Please help. I have a gig on Sunday
What adapters have you tried? The P85 REQUIRES a 12 VAC adapter, NOT the common DC type and it needs a 1.5 amp (1500 ma) type adapter. If you connected a DC adapter it will NOT do damage, the unit just won't work. You can find adpaters on Ebay or Google search.
Aug 26, 2011 | Yamaha P85 88Key Portable Digital Piano
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
Im using a behringer ucg102 guitar/usb interface, im getting a very bad hum/hiss.. i've tried 3 different guitars and multiple jacks. im not running any guitar effects yet, i've removed the...
Try this using a differeent computer. Some computers generate a lot of digital noise. Also use a lot of gain from the guitar to improve the signal to noise ratio.
Jul 23, 2011 | Behringer energyXT2.5 Plus Portable...
After having been in safe waterproof storage during cyclone season I,ve unwrapped my korg pa 500 and plugged it in but it doesn,t boot up .The sreen is lit well with simply "Korg"...
First thing... make sure you are using the KA320 power adapter with it. We will work from there.
The unit probably is sensing an error of some type. Check these things: That NO key or button is STUCK down. Next, one could try reseating the memory sticks if you have expanded memory.
Let me know if you find a button or key is stuck down (not uncommon when unit has been wrapped) or you are using the wrong power adapter.
Jun 10, 2011 | Korg PA500 Professional Arranger 61 Key...
It works sometimes but mostly never. The power is on and the screen is blank.
For anyone who still has this issue including above morris_gray,
I've encountered this myself with my first generation M-Audio Axiom 25 USB MIDI Controller plugged into a MacBook using GarageBand (G2 apparently has identical malfunction).
It should be noted that I never installed any type of software for the device, that came with the device. I simply wanted a controller for GarageBand, and I will also note that it has worked flawlessly for about 4 years on this setup, until about a week ago...
I'll provide what information I have gathered about the blank LCD screen issue as well as the controller simply not functioning correctly as listed below:
The most common way people test/fix this is to "hard reset":
- turn controller off (assuming you've kept the usb cable connected to your computer)
- hold down both the + and - buttons directly below the lcd, and simply turn the power on. Some numbers should appear on the lcd soon after the reboot and you are okay to release said buttons...
I've read testimonials, watched videos of people doing this and successfully getting their device back in action, though the reset will default anything you have saved for the device.
Sadly, this did not work on mine. I've tried several different cables- in several different usb ports- on several different computers (as suggested by M-Audio on their support page. I still get a lit up but blank lcd. I've even tried to still use it but only some awful noises come out and nearly every function just makes the thing freak out and it becomes silent/unusable/useless.
M-Audio suggests sending it back to them for fixing at this point.
Because I've had my Axiom 25 Gen. 1 for so long and I have never installed anything what so ever that came in the box, and have little faith that M-Audio will replace mine, I will most likely try to take it apart and mess around with the electronics inside as it's just a big paperweight now.
I did read that in the Gen. 1's the blank lcd could be a result of a chip gone wrong, so to speak... Gen. 2's had some type of "grounding" issue that resulted in the blank lcd and such.
I hope this helps anyone, if I stumble upon a way to fix this through my own curiosity I will inform the masses...
I'll be on the hunt for a new controller most likely and it probably wont be an M-Audio...not that I'm upset with the product, it lasted me quite a while and I've made a lot of solid songs/music with it, but rather I feel the need for something different and maybe a little more sturdy that can actually be a synthesizer on its own, not just a controller.
- Christoffer
Mar 29, 2011 | M-Audio Axiom 25 G2 USB MIDI Controller
Yamaha DGX-620 blank screen or screen with vertical lines
I`ve had a similar problem with a Korg that I use at the club and on gigs, I don`t know whether Yamaha use a similar method or not but when I stripped mine down, I found that the glass LCD panel is connected to the PCB via a ribbon cable which gets sandwiched between the PCB and the LCD panel when screwed up, It`s not soldered or hard wired to the PCB, It was producing intermittent connections between the uPC and the display panel where parts of letters and symbols were missing. When I removed the panel, I found that it was oxidized so I used some switch cleaner which doesn`t leave a residue (Don`t use lubricant or WD40 as this will destroy the LCD panel by penetrating between the layers of Liquid Crystal rendering it useless) and gently cleaned the contacts on both the LCD and PCB panels (Don`t spray the panel or this could penetrate) by spraying a small amount onto a tissue then gently wiping this into the nooks and crannies with a nail brush then wiping off the excess with another tissue. I`ve had no problems since, (touch wood). Please use extreme caution when working with these panels as they are dedicated to your keyboard and therefore extremely expensive to replace. If yours has an extension lead from the LCD panel to a plug on the PCB, it should be a lot easier to clean this one cable where it enters the plug on the PCB than mine was, but still use extreme care. Best of luck, Ian
Jul 23, 2009 | Yamaha Full-Size Keyboard
Behringer Digital Multi-fx Fx600 Pedal Make Offer Logo
79 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
