Question about Intel DG31PR Motherboard
Intel Motherboard DG31PR overheat Problem it start at 68'c & goupto 75'c system is very slow cpu temperature range from 45-52'c
    President:
  • 414 Answers
Hi..hope ur a pro b4 handling core hardware components like cpu..
well d prob u described can b any one of d following:
i) the cpu fan- a) can be dirty..clean throughly..
b) look if any of the clips mounted into d main board is damaged..
c) try replacing d whole fan..
ii) the heat sink- may b dirty too..clean using a blower
iii) heat sink compund- ie a white paste rendered with a thin film between d cpu n d heat sink..it is seemed to b dried up..clean it using a cloth n re-apply it (available in chip-level spare market)
n.b.: b very careful b4 opening cpu fan n cpu from itz socket..
iv) open cmos utility or bios setup n in temperature settings ignore or disable cpu warning temperature..
v) c if all d electrolytic capacitors (mfd) situated in d north bridge of d main board r ok or not..
vi) download n install any cpu temperature control or cpu cooler software (dis softwares increases d fan speed as n when necessary)..
vii) if all d above fails try replacing d smps (atleast 450w)..
bt itz always better to seek intervention of ur computer supervisior or a pro..
n plz do vote n rate..
Posted on Dec 29, 2010
    Sergeant:
  • 320 Answers
Hi Freeen, Yes indeed 68c to75c is in the range of frying the cpu and needs to be corrected immediately. Several thing could cause this problem. 1. The inside of the computer builds up with dust. Pop the cover off and look, if you see alot of dust built up on the cpu heat sink (small square of aluminum fins on the mother board) buy a can of Canned air (walmart $4-$5) and blow all the dust out. 2. the cpu fan could have quit working( replacements can be found online or at Radio Shack) 3. The least likely, the computer got a bump, drop, kick, fall, that has jarred lose the heat sink on top of the cpu (Radio Shack has heat sink compound, Quick Silver I believe is the name, and don't buy the cheap $3 tube, spring for the $12 tube, it is worth it if you need to heat sink your cpu) 4. The one you can do nothing about is that the cpu has an internal short in which case you could replace the cpu, which involves the above steps 1, 2, and 3 for safe measure. Hope this helps
My system suddenly hang when we restart it, monitor does not get any signal. After when we get rid hard drive motherboard was working. on other system my HDD is working fine.
This is usually dust clogging up the CPU cooler.
When the owner of the PC forgets to clean the fins and the fan of the CPU cooler it plugs up with dust and dirt and looks like the inside of a vacuum cleaner.
There is not enough airflow and thus not enough cooling, so the CPU overheats and the safety circuit shuts the CPU off until it cools down, and the CPU will not reboot the PC until it is cool enough that the safety circuit can reset.
First step remove the CPU fan and check the fins of the CPU cooler. If they are clean, the problem is usually somewhere else.
Oct 03, 2015 | Intel DG31PR Motherboard
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
My system worked properly for last 10 months. but before couple of day system is shout down instantly, i tried to start it again, but after the bios screen shutdown again & again................ after...
hi
maybe the time you install os you did not install properly, or you make an online windows update,
you need to check what application you installed last before you encounter that problem, if still appearing the problem got device manager and disable the "automatic shut down on system failure"
thats it
good luck
Jan 03, 2011 | Intel DG31PR Motherboard
I was unable to find which realtek will suits my motherboard dg31pr. i have downloaded many realtek but nothing is working.
Hello thisisrames!
Intel has all the drivers for your DG31PR motherboard available for download on their website. The link for your motherboard is DG31PR, just choose your operating system from the list. I see Realtek drivers listed for both audio & LAN.
Nov 22, 2010 | Intel DG31PR Motherboard
Intel DG31PR motherboard starts and cpu heated but on the post card it is showing not initialized please solve the problem
Check the RAM modules, reseat to make sure it makes proper electrical contact.
Check the RAM specification and motherboard specification. Is the RAM module the correct type for the motherboard
If it still does not boot up, check the RAM module - take it to your friendly computer shop to test.
Check the CPU, make sure it is seated correctly and locked into position. If possible test the CPU in another motherboard to see if it is faulty.
Sep 09, 2010 | Intel DG31PR Motherboard
Audio driver for intel pentium processor
Open the link provided by Intel below;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22DG31PR%22
Click on your current operating system (Middle Window) & than click on Drivers (Right window). Drivers are operating system dependent.
Have a nice day!
Mike
Jul 21, 2010 | Intel DG31PR Motherboard
I have Intel DG31PR series motherboard with 2GB
The number of the beeps is a specific post
error code and should help diagnose. e.g.:
my computer has 3 beeps to indicate RAM
failure. Note the beeps and find in your manual
or from Intel support.
Here's some help to get started:
Beep Codes
Intel Support
Jul 12, 2009 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
495 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
