Question about HP LaserJet P3005 Printer
My HP Laserjet 3005 has faint print on the righthand side for at least the first 2". I have fitted a new toner but this has made no difference. Could this be the fuser unit?
  • HP Master
  • 1,719 Answers
If it happens even after replacing the toner cartridge or if you current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printers, which partially blocks laser beams and requires cleaning/ servicing by a professional.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Posted on Dec 29, 2010
10.1000 error showing in HP laserjet 3005 printer.Waht is the scientific side to resolve the issue?
error refers to memory on print cartridge that cannot be read. Replace toner cartridge.
Nov 13, 2013 | HP Stacker For LaserJet 9040/9050/9500...
HP 3005 MOVING TONER TO ANOTHER 3005
Sure.... never should be a problem.....Each toner cartridge has a memory card and informs the printer of the amount of toner left.
Dec 07, 2011 | HP LaserJet P3005 Printer
Just changed the toner and the printer now prints faintly
There are two reasons for faint/ light printing:
1- Toner Saving Mode may be turned-on from the printer OR from printer settings in windows
2- There could be dust/ Toner Dust accumulated on the mirrors and lenses inside the printer, which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hope this helps!
CreativeTECH
Dec 20, 2010 | HP P2055DN LaserJet Monochrome Printer
I have refilled my HP LaserJet M1132 MFP toner and the print quality does not look good. It is very faint and if I try to increase the contrast, it is not readable. Please advice.
Nov 19, 2010 | Office Equipment & Supplies
When copying or printing, there is a whitish strip down the center where the rollers are. Print in this area is very faint. Thank you for any advice.
Remove the toner cartridge and while keeping relatively level, shake it from side to side. Re-install and try a test print. If the light band has gone away then problem solved. It does mean that your toner crtridge is probably starting to get low on toner. 90% of the time, print quality issues on HP lasers are toner cartridge related.
Good Luck and Thank You for using Fixya.
Aug 05, 2010 | HP LaserJet 3050 All-In-One Printer
HP-LASERJET PRINTER PROBLEMS   HP-3005 NO PROPAR PRINT OUT      NOSE PROBLEMS
Check one of the followings:
Paper jammed anywhere visible? Rollers, etc?
All the trays are closed properly?
Toner, Drum Unit or the Fuser Unit don't need changing?
See if you can print out the Printer Status of the Printer from it's menu which would give you some statistics of what needs to be replaced etc.
Contact your HP Dealer nearest you to fix that problem, it could still be under warranty so there'll be no added cost to you.
All the best!
ramatau
Jan 29, 2010 | HP LaserJet P3005n Printer
Need teflon for HP laserjet 3005
www.hp.com seems to be the place to start looking for OEM parts
Jun 12, 2009 | HP LaserJet P3005n Printer
Two printers print only black
Swap all toner carts on both machines. Sounds like a toner cart problem
Jan 30, 2009 | HP LaserJet 2500 Printer
Hp laser jet 2100 faint printing
Reinstall the printer driver again to check if driver has gone bad or not.
Dec 02, 2008 | HP LaserJet 2100 Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
HP LaserJet P3005 Printer Logo
298 people viewed this question
Seeker5211
Seeker5211
