Question about Motorola Cell Phones
How do I pair my older Motarola H-500 bluetooth with my new phone? I don't have the password anymore>
  • shellnbs Jul 07, 2008
    Thanks !!
  • 405 Answers
Good Day,
Passcode is "0000"
Hope this helps
Posted on Jul 07, 2008
I have a pantech ease phone and I received a plantronics 925 bluetooth and having difficulties pairing it/ setting it up. please help
1. Tap Menu > Settings > Bluetooth > Search.
2. The available devices will display.3. Tap to select the desired device.4. Tap Pair to pair the device.5. Enter password > OK. (should be 0000)
Jun 28, 2011 | Plantronics Discovery 925 Bluetooth...
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
I need the password for my bluetooth explorer 390
If you forgot your password, please try below instructions:
How to Pair Your Headset If it Has Been Previously Paired With Another Device:
1. Turn the headset off. Press and hold the call control button until the indicator turns red and then turns off.
2. Turn the headset on. Press and hold the call control button until the indicator light continues to flash red and blue. The headset is now in pairing mode.
3. Use the commands on your phone to locate your headset. For most phones, select Settings/Tools > Connections > Bluetooth > Search > 3xxPlantronics. See your phone's user guide for more information.
4. If prompted for the PiN code/passkey, enter 0000.
Pairing is successful when the indicator on your headset flashes blue. Your headset is now connected and ready to use.
NOTE This headset is equipped with Secure Simple Pairing (SSP). If your phone supports SSP, you will not have to follow step 4; you will instead see a message on your phone alerting you to a successful pairing.
Feb 18, 2011 | Audio Players & Recorders
Trying to connect Plantronic 220 headset to Pantech phone. Can't find the right option on the phone to engage the bluetooth device. I think the headset needs to be flashing red/blue to pick up device and...
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Nov 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i pair sp 500 to my nokia n95 mobile
The Jabra user manual is located below - you'll need to reference it to determine which button is the Pairing button. After you turn on the Jabra, press and hold the pairing button until the blue light is solid (approximately 2 seconds). Set your phone to discover mode as follows:
Go to the Bluetooth menu under the Tools menu item
Select Options > New Paired device.
Select the device and enter 0000 as the passcode.
If you want the device to automatically pair when they are within range of each other, select the device and select Set as authorised.
That's all there is to it.
Feb 20, 2010 | Lands Phones
Pairing my bluetooth
most bluetooth headsets pairing codes are either 4 zeros or 6 zeros.
if you need anymore help we are here to help! Call us M-F 9-6 Sat 11-2 317.337.0030
Nov 11, 2009 | Cell Phones
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Cell Phones Logo
19 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
