Question about Cell Phones
Water damaged doesn't start now - Cell Phones
    Sergeant:
  • 187 Answers
You have to contact your nearest mobile service provider
Posted on Dec 29, 2010
Water bubbling to the reserve when engine is off, changed radiator cap it was damage on the rubber part still bubbling
It will be a bad thermostat or water pump. Change the thermostat first as it is cheaper. If that doesn't fix it the water pump is bad.
Oct 14, 2012 | Cars & Trucks
The washer will not go into spin mode or drain the water
see this cause:
t spins, but doesn't pump
drain line is clogged,remove the large hose that connect to pump to bottom of outer tub remove the cloth with pliers, propeller pump damaged replace
It doesn't spin or pump
frozen pump pulley replace pump,check manual, if doesnot replace it
It pumps, but the water returns
drain hose if reache more 4inches, cut ot the remain.if lower install air/gap siphon break assembly.
God bless you
Jun 19, 2012 | Washing Machines
My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Mar 14, 2012 | Washing Machines
LEAKING SMALL AMOUT UNDER MACHINE
It's a bad seal, if it doesn't leak enough to be a nuisance or cause water damage i wouldn't worry about it. It would most likely be more hassle than worth. But if its a newer machine or water damage is a factor your going to have to run your machine until the water starts coming out and then disassemble it and locate the bad seal then order a new one and install it.
Dec 17, 2011 | Washing Machines
How do n1280 network problem water damage
Please let me know more information, what I think has happened is that you dropped the phone in water and now it is turning on but you get a network problem constantly. If that is the case...
It is probably your phone's SIM card that has been damaged by the water. Go to your phone store or call customer service to get a new SIM.
If the new SIM doesn't solve the issue your phone has been damaged and may be unfixable. But, before you give up, get that new SIM.
Sep 02, 2011 | Nokia 1280 Cell Phone
I can start and drive for an hour or so but in really hot weather my car will start running slow then stalls and when you go to restart it it will start then shake real bad and stall again. i have replaced...
Make sure that you don't have to much antifreeze in coolant system. A 50/50 mix is to much and doesn't keep the system from freezing or from overheating. You need something like a 30/70 mixture, then make sure that your coolant system doesn't have any air bubbles in it. You do this by starting the car with the radiator cap OFF, let it run until it reaches operating temperature. You should see a few bubbles, it might even belch up some coolant. After it has stopped making bubbles and you can see the coolant flowing in the radiator top it off with warm water. Even if you just fill a couple jugs and put them in the sun before you start. If the water is to cold it can damage your coolant system. Hope this helps let me know.
Aug 03, 2011 | 2000 Daewoo Nubira
Water will not shoot out....took the hose off and it still doesn't work
If this model has a quick disconnect coupling for the pressure hose opposite of the sprayer wand at the pump, remove with a wrench. Hook up the water hose, turn on he water , but don't start the engine. If it has a clog this will flush out the clog. Replace the coupler and hose, turn on the water first before starting the engine. If the pump builds pressure it will make the motor bog down slightly. If there's no change in the sound of the engine with water turned on, the pump will be damaged. If the motor bogs off and on and water sprays on and off, means there is an air leak in the pump. If the pump does not work at all with the water turned on, the pump will be burned up. Please don't take this in offense; but I've seen many power washer pumps damaged because the water was not turned on before starting the engine. Try these few steps and let me know if you get any pressure at all, if so it's probably an air leak. Good luck!
Jun 21, 2011 | Mi T M Mi T M CV 2400 Cleanmaster 2400...
My touchscreen doesn't work,
Usually when touch screen doesn't work, it's a sign of water damage. It's also possible that you dropped it at some point and ruined the sensors inside. But it's PROBABLY water damage. What you can do is bring it to your phone carrier's closest store and ask them to check if your phone suffered water damage. They'll open the phone up and look. If it is water damage, you'll probably have to pay for a new one...If you're insured, it probably won't be that expensive.
The good news is, if you bring it there and it ISN'T water damage, you probably won't have to pay anything at all for them to replace it. Hope this helps!
Please rate my solution!
- Frankie
May 06, 2011 | Samsung Star GT-S5233 Cell Phone
Hi i have a whirlpool WFS1072AW Front loader 7.5 kg we load the washer as normal press start and then this horible noise comes from the back no water goes in just the noise like gears grinding
Hello Steve.
First off is this a new washer?
If so front load washes ship with retaining plugs / pins in the back. They do this to stablize the drum in shipping so it doesn't get damaged. Check the back and see if this is the case. There should be 4 or so to remove. Also don't throw these out, if you ever need to move you will need them to make sure the washer doesn't get damaged.
Hope this helps.
Good luck
May 02, 2011 | Washing Machines
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
