Question about Total Training Flash CS4 Essentials Government License (LFLASHCS4)
Hi i buy a education film about 3dmax films are lock by zip and where must be enter serial cd, made by flash cs4. i enter true serial at windows 7 but show this: your serial is not true. but in xp work. please help me to solve this or find password to extra video files.
    Guru:
  • 223 Answers
Hey, in your case, you can try Smartkey ZIP Password Recovery. It can help you remove ZIP password.
Posted on Mar 31, 2011
My new password wii be. SPUNky13. Is that OK?
PI
Posted on Feb 06, 2012
I have an Epson expression 1680 with the latest drivers and a usb hook-up to my Windows 7 computer. I can scan, the computer recognizes everything but I cannot get it to work to copy film...it won't let me...
Hi, most if not all scanners don't work when you try to use it on film. Usually, the only way for you to scan film or transparencies is you have to buy an accessory for the scanner called a "transparency unit" which does not come installed with your scanner when you buy it. Unless your scanner says that it came with that accessory then you won't be able to scan films or transparencies at all.
Feb 05, 2018 | Epson Expression1680 Professional Desktop...
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
The flash sometimes doesn't work and prints out white film
Hi, once you insert the new pack of film, first shot is without flash as it's eject the film cover which is a useless film cover that cover the film protect the film being exposed. after first shot, camera will have flash. but do not open the film cover again. if you open and take out the film it will expose to light and film turn out to be white.
http://www.passiongadgets.com/
Apr 13, 2014 | FUJIFILM Instax 210 Film Camera
Looking for the Vupoint Filmscanner driver. Thanks for helping..
Hi Thierryghi,
thanks for explaining in detail.
Please download the driver for your device from the below link.
ftp://vps:vps@66.185.19.4/Drivers/FS-C1-VP.zip
But I am not sure whether it will be compatible from Windows 7.
Try installing the driver. If not installing on win 7, then right click on the setup.exe and select properties. There select compatibility to windows xp as something similar like below.
After installing the driver, you need to install software so that you can use that software to scan.
Please download the software from the below location and insatll this as well after installing the driver.
ftp://vps:vps@66.185.19.4/software/PhotoImpression_6.1.8.130(new).zip
After installing this s/w you will be getting some shortcut in desktop using which you can scan your film.
I hope this will be useful to you.
Thanks
Mar 10, 2010 | Office Equipment & Supplies
I was wondering if about the flash feature.
Hi Amber,
Yes, you would need film. The film pack contains the battery that powers the camera.
For reference, see:
http://www.polaroid.com/media/document/one600jobpro_ug.pdf
Thanks for using Fixya.
Feb 25, 2010 | Polaroid One600 Pro Instant Camera
I cant install the adobe photoshop cs4 becouse i dont i have a license serial number.. would you pls give me a valid serial number for adobe photoshop cs4!!
if u want that for free just download a keygen.
or try the PORTABLE VERSION of CS4 thts free. You can find these on rapidlibrary
Nov 19, 2009 | Adobe Photoshop CS4 Extended Full Version...
Cannot find the right film for my fujifilm cammera
Try to find a good camerashop they can order this type of film for you.
regards,
Rob
Mar 15, 2009 | FUJIFILM CD-R Storage Media
Film advance
throw it away, its already old, buy new ones a pentax g40, its a computer compatible.
Feb 28, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
Total Training Flash CS4 Essentials Government License (LFLASHCS4) Logo
55 people viewed this question
Top Total Training Computers & Internet Experts
David Payne
David Payne
Are you a Total Training Computer and Internet Expert? Answer questions, earn points and help others
