Question about Whirlpool Microwave Ovens
I bought a used maytag model mmv5165aas over the range microwave oven and need the mounting templates and manual for it. and suggestions on where to find the or who is selling them other than whirlpool(can't get thru to them)
  • Whirlpool Master
  • 9,086 Answers
You can download the owner's manual and installation instructions here.
You can usually find helpful exploded view diagrams and order needed parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 08, 2008
Just bought a used MC0153UW and need access to installation manual so I can mount over the range. Any suggestions?
The installation manual is here: http://www.microwavedisplay.com/mco153uw_om.pdf The owner's manual is here: http://www.microwavedisplay.com/mco153uw_inst.pdf
Oct 17, 2013 | Magic Chef Over The Range Microwave
Over The rang microwave installation
I would say finish the wall, because the microwave needs the space for cooling.
Dec 17, 2017 | Samsung Microwave Ovens
The instruction manual was not in the box when we bought our new under cabinet mount Maytag microwave (model MMV1163DW00) We just have a basic mounting question. What is the best way to mount our...
run a search for maytag microwave model mmv1163dwoo, then scroll down to installation guide/manual, it was at www.managemylife.com, page 7 in the manual, I believe.
Mar 03, 2011 | Maytag Appliances Over-the-Range Microwave...
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Jan 10, 2010 | GE Profile Over-the-Range Microwave
When installing over the range microwave does template need to be removed
the paper template that they send to mark for mounting instructions? yes...another template you're refering to?
Oct 25, 2009 | Bosch Microwave Ovens
How do I mount a maytag mmv4205bas microwave? I bought a floormodel and they did not have the template.
Go to this website:
http://www.servicematters.com/maytag_library/html/index.html
-Once there click the link at the top "Literature by Model"
-Now enter your model number "MMV4205BAS" and hit enter or "go"
-On the page click your model number
-Click on the first row or the row containing the Document Type of Service Manual
-On page 51 of that PDF you will see the installation instructions for your microwave.
Apr 09, 2009 | Maytag MMV4205 Microwave Oven
Maytag - MMV5165AAS
If it is under warranty, call service. I experienced similar odors, sounds, and failure to heat meals. The magnetron/emitter and the transformer are replaced on two separate failures. Now the third time just happened. I am afraid mine is out of warranty and I will not purchase Maytag again.
Aug 12, 2008 | Maytag MMV5165 Microwave Oven
Microwave Ovens Logo
143 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
