Question about Pioneer DJm500 Professional DJ Mixer W/Effects System
During an attempted Robery two of my (DJM-500) input selection switches on channel 3 & 4 got damaged. Where can I find replacement switches? I can replace them myself.
  • 1,557 Answers
Sorry to hear i contacted pioneer for you not an easy part to find if you send me a picture of the switch i can match it to tens of thous that we order cheers
sonicboomelectronics@hotmail.com
Posted on Dec 29, 2010
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    Wiring diagram,connecting DVD & VCR to a television
    Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
    For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
    Aug 23, 2010 | Televison & Video
    Djm 500 mixer cf missing and does not turn on does it need the cf to turn on?
    no and you can use channel fader of each channel to control the channel without cross fading.
    Dec 18, 2009 | Pioneer DJM-600 Silver Professional DJ...
    I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
    If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
    Nov 18, 2009 | Sanyo DS27930 27" TV
    How do i connect a pioneer djm 500 mixer to a dbx 215 equalizer
    You can use either (2) XLR mic cables or (2) balanced 1/4" cables running from the Master Out of the djm 500 to the dbx 215. Then you connect your amp to the outputs of the dbx 215.
    Joey Clay
    Oct 14, 2009 | Audio Players & Recorders
    Piuoneer DJM600S feedback and cd input problems
    Check List :
    CD Deck 1 to Channel 1 CD Input
    CD Deck 2 to Channel 2 CD Input
    Mixer booth output to AMP's AUX or CD input.
    use the BOOTH rather than the MASTER
    even if you think you've done all these checks, check them again.
    trust me I've been a DJ for 15 years & wired up **** loads of systems & still manage to ******* the wiring now & again lol.
    you mite need to run an earth from your mixer to your amp.
    One more thing, just out of interest you don't happen to have an amp with surround sound do you?
    because if you do then switch the effects completely off this should sort it.
    e-mail djtatty@hotmail.com
    Jul 10, 2009 | Pioneer DJM-600 Silver Professional DJ...
    PIONEER DJM500 CHANNEL SELECT SWITCHES STUCK
    take your headphone jack converters and use large converter and plug into the channel 4 submic. take cord off of basic technic stereo dh1200. detach cord and plug into ipod, then into converter and push PLAY wohooo. Music will come out of whichever assign A or assign B knob channel you set it too. If you don't know where that is. It is close to the crossfaider.This is for a DJM-500.
    Bravo to ZOE,
    www.whitecollarcrew.com
    Dec 30, 2008 | Pioneer DJm500 Professional DJ Mixer...
    Pioneer DJM-400 mixer turns on, but channels aren't working
    could be a few things , what have you tried to trouble shoot the problem ?
    My steps would be ;
    check all leads (even if you KNOW u pluged them in)
    check the gain is set corectly .
    check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
    if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
    the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
    Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
    New DJM 600 User
    Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
    Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
    - OPTiC
    DJ Equipment Repair & Service
    A DJ Pro Audio Co.
    Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
    Pioneer djm-600
    the rcas need to be resoldered
    Aug 11, 2007 | Pioneer DJM-600 Silver Professional DJ...
    Pioneer DJm500 Professional DJ Mixer W/Effects System Logo
    97 people viewed this question
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    John
    John
    T-Comtech Repairs
    T-Comtech Repairs
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
