I don't see the green port to connect logitech speakers on my Sony VAIO desk top computer; I only found a mic & earphone ports on a side of the computer, I need to locate the green port to connect speakers. The computer is a VPCJ1 series
I have harman kardon speakers and I cannot figure how to connect with my computers, both desk top or laptop. There are two speakers with a cable with a light green plub and another plug that has me...
The green plug needs to be plugged in into either a green jack at the back of your computer or into your laptops earphone jack. And if the second cord is a USB cord then plug it into a USB port. If it is a power cord then plug it into a wall socket.
Mar 12, 2011 | Computers & Internet
How do i connect my logitech x-230 speakers to my laptop?
Hi, Thanks for using fixya.
On the top close to the screen, side or back of your loptop you should have a speaker port and a mic port plug the speaker wire in the speaker port.
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
Feb 21, 2011 | Logitech X-230 Computer Speakers
I think I might have my speakers hooked up to my computer wrong. I get no sound. Can you give me instructions on how to hook them up?
If you can get around to the back of your PC they should be colour coded, green to green (speakers) pink to pink (mic) etc,
If they are not colour coded, play something and then get back there and move the port one by one until you hear it playing. You will definitely find the mic port easily as it should have a image of a mic stamped onto the metal by the port, its the speakers that are a bit harder to work out from the images
Let us know how you get on :)
Oct 31, 2010 | Logitech Z-640 Computer Speakers
Having speakers to work on vizo desk top . all in on desktop!
You need to remove the unknows first. Try the speakers on another device. You could try a walkman, another computer or anything with an 1/8th" Stereo jack. Prove that the speakers work or get a pair of headphones to check out your PC. If you are using the green jack on the back try the headphone jack on the front. If the front works and the back doesn't check the sound card options / set up. Some have an icon by the time in the bottom right corner others will need to be found under the sound effects manager or the sounds and audio devices icon. I suspect if you get this far something has been turned off in the software.
May 11, 2010 | Sony VAIO VGC-RB34G PC Desktop
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
Go to control panel>hardware and sound>Sound...Then make sure the speakers are set as your default device.
hope this helps
Mar 19, 2010 | Sony VAIO VGC-RB34G PC Desktop
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
I have windows vista computer .ihave bought a sony srs-a201.could you please direct me to where in my tower to conect into.thanks ..cecil
Dear Cecil_willia,
Generally there are three ports for the audio, in computer(Pink,pale green,cyan). Pink color is for mic,middle palegreen color port for Speaker,you have to connect your sony srs-a201 to this port.last one cyan color port for line in. I think it help to solve your problem.If any query back with more information about the problem.
good luck
chandrashekhar
Jul 29, 2009 | Sony SRS-A201 Computer Speakers
How to plug in system speakers on my acer desk top
look for a green port at the sides thete should 3 similar ports green is for speakers and pink is for thr mic
Jul 27, 2008 | Acer Computers & Internet
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
