Question about Car Audio & Video
No sound Just recently my amp just stop puttin out sound . all the wires are hooked up, check da fuse its ok and the blue power light is on but no sound.
  • 21 Answers
Ok i think you might be lucky, i just had this problem for like 2 months.........k with your cd player on, get a multimeter turn it to DC volts, put the black probe on the ground of the amp and touch the red the power or remote, if its under 11 volts you found it....most likely its the fuse right off the battery check it at the far side with the multimeter......hopefully this helps
Posted on Jul 09, 2008
I put a Pioneer AVH 1400 DVD in 06 solstice have it hooked up working but no sound through speakers I have hot ground remote and speaker wires hooked up what other wires have to be hooked up 4 sound
If the car had an amplified sound system prior to removal you will need to turn on the factory amp. You need to hook up the blue wire with the white stripe. You may have a dedicated wire that you need to hook it to or you may have to hook it directly to the 2 blue wires for the power antenna. Now you may not have a power antenna but hook them up anyway. If that doesnt work you have a dedicated amp turn on wire. If you find that and it still doesnt work check your fuses for the amplifier with a digital multimeter. Replace any blown fuses that you cant find
Apr 17, 2016 | Pioneer Car Audio & Video
I just bought a hifonics amp the brz2100.1D and when i tryed to hook it up every thing is correct as far as the wireing compared to the manual and the blue lights come on power light is on but its not...
MAKE SURE YOUR GROUND WIRE IS GROUNDED GOOD,,AND IT IS IMPORTENT TO HAVE YOUR REMOTE WIRE HOOKED UP. IT WILL BE A BLUE WIRE,,FIND THE HOT WIRE FOR YOUR TAIL LIGHTS AND HOOK IT THERE THEN WHEN YOU TURN YOUR CAR ON THE AMP WILL ALSO COME ON.THAT SHOULD STOP ALL THE NOISE AND POWER YOU UP.
Jul 15, 2011 | Hifonics BRZ21001D Car Amp
Would a bad Flasher relay cause the brake lights not to work?
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
Feb 06, 2011 | 2004 Ford F250
Only one channel is puttin out sound and its vary low power i have checked all the connections and they are all hooked up right any idea on what the problem(s) could be?
Try checking the fuses... How Many amps is the fuses u are using ? most of the time it is best to match the fuses with the amplifiers output. check the fuses also to see if any are blown or broken, or the nobs on the amp. there are controls on the amp u set to putout the amount of bass u want and other setting u want your amp to be set at.
Hope this helps.
Oct 07, 2010 | Legacy LA2259 Car Audio Amplifier
I installed my amplifier today and it doesn't seem to turn on. I connected the remote wire to the dark blue wire on my harness on my cd player. The power wire is running from the battery and the ground is...
Check the fuse sometimes when hooking them up youll blow a fuse.but make sure your ground is to bare metal no paint should be on it. very important.. also make sure the blue wire has current using a light tester or volt meter. if you have a long wire run it directly from battery to see if its the remote wire . sounds like a bad ground is the amp new what is the brand
Oct 03, 2009 | Car Audio & Video
My amps not working anymore.
first check your ground wire then you power wire connections .. check the fuse to see if its making connections on both ends of the wires..
i think the flickering is the result of a weak or bad connection in the power ground or acc wire "normaly blue"
your amp has no sound because the amp has to charge before it can out put at a higher amperage
hope this helps
Dec 21, 2008 | Car Audio & Video
Dont know whats wrong
You can check the fuses if it has more than one. Or another thing that might be wrong is that you might have to big of a speaker hooked up. Or your power wire might be to small because if its two small then the amp cant get enough power to power a big speaker.
Jan 25, 2008 | Earthquake Sound PH-D3 Car Audio Amplifier
No audio-amp protect light come on then went
You need to check the DC voltage across the B+ and ground terminals. You also need to check the DC voltage across the remote and ground terminals. If the voltage is less than 11 volts, you need to check the B+ supply and remote wiring for breaks or open fuses. You should also check the ground connection to confirm that it's not loose.
If the voltage is OK, the output transistors are likely shorted.
Oct 21, 2007 | JBL GTO75.2 Car Audio Amplifier
Car Audio & Video Logo
145 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
