Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon Mp 210 Scanner printer
When I scan documents as text, the scanner puts it through as a photo.
I need to edit the text pages.
  • 3 more comments
  • solbluesun Jul 07, 2008
    When Im trying to scan a document is not working properly, instead do not scan the document and do not appear as I scan something
  • Anonymous Feb 13, 2009
    i have canon 210 and it doesnt work when i hit scan
  • Anonymous Apr 23, 2009
    i changed the wia to manual, it started to work a bit, then stopped
    it doesnt give me any notices where it is scanned or saved
    how will i find out where the document is on the computer miser 22 can you help?
  • Anonymous Apr 04, 2010
    photos come faded --just installed new ink cartrigdes
  • Anonymous Mar 14, 2014
    I NEED TO SCAN A PHOTO FROM THIS SCANNER/PRINTER CANON MF4380-4390 AND WHAT STEP BY STEP RPOCESS IS INVOLVED INVOLVED?
Go into administrative tools click on services and make sure windows image acquisition (WIA) is on manual
Posted on Feb 27, 2009
I have a scanner MP360 and it does nothing when I hit scan but it copies to print fine.
Posted on Nov 29, 2008
How do i get my scanner to operate - I put a piece of paper on the glass - hit the scan button - then nothing happens - the printer says " PC scan standby" . What do I do next ? Do i need to...
1. Install the MP Navigator EXsoftware located on the disc that came with the printer.
2. Go to Start > Programs > Canon Utilities > MP Navigator EX > MP Navigator EX.
3. Select Photos/Documents or Stack of Documents.
4. If Photos/Documents was selected, open the top of the scanner and place the document you wish to scan on the glass with the top facing to the left. If Stack of Documents was selected, flip the plastic tray open on the top of the printer and place the stack of papers in the tray.
5. Select the Document Type in the left pane, then click the Scan button.
6. The scanning process should start. When it's finished, select Save to save the document(s) as a JPEG, or select Save as PDF to save it in PDF format.
Jul 07, 2011 | Canon PIXMA MX340 Wireless Office...
My Cannon Pixma MP500 multi-function printer randomly scans only part of the document on the glass. Sometimes it does get it right; that is it correctly scans the whole page, but very often, the scan...
Try to adjust the scanner resolution
Solution: Adjusting Output (Scan) Resolution (Windows) - MP150 / MP170 / MP450 / MP500 / MP800 / MP950
Adjusting Output (Scan) Resolution By changing the resolution, you can set how clear the image is going to be.
The higher the resolution, the clearer (but the larger) the scanned image is.
The resolution can be changed before scanning. (Note)
If the resolution is doubled, the image data will be quadrupled.
If the data is large, problems such as slow processing speed or lack of memory may occur.
To change standard scan settings using MP Navigator, click here
To change more advanced scan settings using the scanner driver, click here
Using MP Navigator
  1. Place the document face-down on the platen glass.
  2. Launch MP Navigator.
    1. On the Windows desktop, double-click the 'MP Navigator 2.0' icon.
    2. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator 2.0' folder, then 'MP Navigator 2.0' icon.
  3. Click 'Scan Photo/Document'.
    Display varies according to the printer model.
  4. When the Scan Photo/Document window is displayed, click 'Specify'.
  5. When the Scan Settings window is displayed, select the resolution in Scanning Resolution drop-down.
    Select from the following scanning resolutions:
    [Text(OCR)]: 300/400/600
    Other: 75/100/150/200/300/400/600
  6. If necessary, set other items as well.
  7. Click 'OK'.
  8. In the Scan Photo/Document window, click 'Scan' to start scanning.
Using the scanner driver
  1. Launch MP Navigator.
  2. Click 'Scan with Scanner Driver'.
  3. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    To set the resolution in Simple Mode:
    (A) Select the 'Simple Mode' tab.
    (B) In Destination drop-down, select the resolution which suits the purpose.
    To set the resolution in Advanced Mode:
    (A) Select the 'Advanced Mode' tab.
    (B) In Output Resolution drop-down, select one of the preset resolutions, or enter a number from 25 to 19200 to specify your favorite resolution.
  4. In either Simple or Advanced Modes, select other settings as required and then click 'Scan' to start scanning.
Aug 13, 2008 | Canon Office Equipment & Supplies
I dont have the on screen manuals in order to use my Canon Mp210 scanner The printer and scanner are all in one. I put a photo or document in the scanner and turn it on, it seems to be on and ok, except I...
To get the manual go here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals .
Drivers and software for supported OS versions are available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#DriversAndSoftware . If you want the scanner to work when you press the buttons on the unit, you will need the MP Navigator.
If you connected the USB cable and got a generic driver, uninstall that driver and then disconnect the USB cable before installing the software from the above site. This generic driver usually only runs the printer.
There is a monitor program that listens for button presses on the all-in-one. This must be running to scan from the unit. However, the software must be set up with destinations and default settings before the MP Navigator will work with those buttons. Thus you should first launch the software from the computer and learn the resolution and other details to set as your defaults. Place documents face down on the glass or face up in an Automatic Document Feeder.
If you have some versions of Windows, you can acquire scans if the basic Canon driver is installed without the full Canon software. For XP, Vista and Win7, Paint will work - File > Import from Camera or Scanner > New Scan. Vista and Win7 both have Windows Fax and Scan (New Scan). Vista includes Photo Gallery which also imports from the scanner. (For Win7 this is part of the Windows Live free download but isn't preinstalled.)
I hope this helps.
Nov 23, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Jan 05, 2010 | Canon PIXMA MX310 All-In-One Printer
How to use scanner for mp 210 series
You can Scan image from the machine into a computer and save them in,JPEG,TIFF,PDF or BITMAP format.
Scanning Methods:Scanning Using The MP Navigator- Using the MP NAVIGATOR you can Scan process and save documents to your computer.On the MP Navigator 3.0 double click then open it and via:
1 Easy Photo Print(Photo Printing)
2Arcsoft Photo Studio(Photo Image editing )
I shall try to help you
Thanks
Nov 27, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Scanning
As with most scanners, place the document in the scanner for scanning. Open the software that you wish to use. Select "File" from the menu and then "Import". Your scanner interface listing should appear. Click on the device to begin your import from your scanner. Your scanner should scan the document and it will appear in your application. Be advised, Scanners scan in a Graphic format. To edit in a wordprocessor you will need some kind of OCR (Optical Character Recognition) Software to convert the graphics into a wordable form for editing.
Jun 11, 2009 | Canon Pixma MP480 All-In-One InkJet...
Problem using OCR with Canon MP610 all-in-one
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
Dec 15, 2008 | Canon MP610 Photo All-In-One Printer
My Canon MP510 scanner won't scan - the printer works fine, but I can't get it to scan. It used to work just fine.
Try using your scanner from your computer, I'm using windows XP and when i go to My Computer and the printer is connected i see a section that says Scanner and Cameras, your printer should be there, click on it and follow the easy step to scan a document.
Nov 28, 2008 | Office Equipment & Supplies
Slow scanning
I had the same problem on a Mac after upgrading OSX (on 10.5.7 now).
Downloaded the newest scanner driver from Canon:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=13800
and now it scans without delay!
I always scan using MP Navigator, not from the scanner itself: let's me edit the scans and save where I want as .jpg or .pdf.
May 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
975 people viewed this question
old marine
old marine
