Question about Brother ML-100 Typewriter
Correct key whenever i press the correction key its not correcting
  • 186 Answers
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Posted on Jul 18, 2008
Describe your nakajima ae-800 Problem : When I press the correction key it sometimes does not stop correcting . What's wrong with the machine ? My supplier told us to change 2 key switches and lift off...
It sounds like the correction key is sticking down or you had a keyboard spill. Press the correction key and see if it comes up quickly. If not gently pry the key off look for debris or stick residue under it.
DickyO
Jul 14, 2011 | Nakajima AE-800 Typewriter
My keyboard has suddenly stoped working correctly, I think its due to me messing around with the Function Keys. Any ideas
I believe the num lock key is truned ON. IF yes, then whenever you type, it will give you only number. Try the steps below to unlockit:
Keep on holding the "Fn" Key and then press F11 (Numlk) key. i.e Fn+F11
It should take care of the issue.
Thanks and regards,
Jitha
Jan 27, 2011 | Acer Aspire 4720 Notebook
How to correct mitake after taking documents and feeding it second time? which key I have to use for that purpose
Using the space backspace und paper up and down keys get back to the error press correction key, then the letter to be corrected.
DickyO
Aug 21, 2010 | Olympia Startype 3 Typewriter
How do i correct one digit at a time. I only seem to be able to correct one word at a time.
Hold down code and press the correction button to switch from word correct to character correct and back. Note to correct one character only you can simply use the backspace key.
May 14, 2010 | Smith Corona Wordsmith 200 Typewriter
Correction key problem
To correct press the correction key just above the ret. key. If you are passed the error backspace to it and press the corr. key.
DickyO
Aug 04, 2009 | Olympia Mastertype 3 Typewriter
Renault clio radio
You do not use the buttons.
You have to use the Steering Wheel remote Control
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [¬ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Sep 13, 2008 | 2000 Renault 181
Nokia 6230 keypad problem
sounds like the phone got wet or was left inVERY humid enviroment Clean ALL corrosion from the contact points and the back of the phone's logical key pad(where the electronics are) other wise get it replaced....
May 28, 2008 | Nokia 6230
Typewritter won't correct!
After you press the corr. key you must retype the wrong letter then type the correct letter.
DickyO
May 15, 2008 | Office Equipment & Supplies
Set correct time on Logitech MX 3200 wireless keyboard
Cordless Desktop MXTM 3200 Laser
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
Dec 31, 2007 | Logitech Wireless Access Duo Optical...
Brother ML-100 Typewriter Logo
169 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
