Question about NorStar Meridian M2616 Phone
The DN labels for my M2616 are gone, how can I check the respective features e.g. call fowarding at the individual DN?
How to assign a dn number to M7324
press Feature *0 (button inquiry) then press the intercom key.
When a set is installed it automatically gets an intercom #
Mar 19, 2014 | NorStar M7324 Telephone
Epson B- 510 DN printer error printer restart 0x95 error
Epson Printer Error 0x95 occurs when the printer head has gone empty or you can say that it has become completely saturated. The reason for this Error may be issues in installation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Steps to Fix Error 0x97 in Epson Printer:
Solution 1: - Check Epson Printer Ink Head
Printer ink becomes dirty because the ink pad is full. Due to unbalanced ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
If this step is not working to fix Error Code 0x95, then go to next step.
Solution 2: - Manually Perform Steps with Epson Printer
  • Switch on your Epson printer.
  • "press+hold" together to stop ink power buttons.
  • Wait for sometime while the printer switches self OFF.
  • Switch ON again and your error should have gone.
Solution 3: - Run the System Under Safe Mode
You should try to run the computer under safe mode, and then you may receive a message from the system about your error existence is effectively solved or not.
Solution 4: - Uninstall Current Installed Software From System
  • On your Windows "Start" button, go to "Programs and Features".
  • In the "Control Panel", tap "Programs", and then tap "Programs and Features".
  • Choose that software program that you have just installed, and then tap on "Uninstall" button.
You can visit Epson Printer Support Number if you are still unable to resolve the Error.
Jan 24, 2014 | Office Equipment & Supplies
Message light keeps flashing on my Meridian M2616 phone after I have checked the messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Apr 16, 2013 | Nortel Lot 16 Meridian M2616 M 2616 Phone...
Change date & time on meridian M2616
how do I change the time on the phone from 24 hour clock to 12 hour clock
Aug 16, 2010 | NorStar Meridian M2616 Phone
My number was forwarded to my secretaries desk so it gives a quick ring in my office but goes directly to her...How do I get my calls to ring in my office. I believe a code was used to send the calls to...
To foward (and un-foward) calls you press feature 11 your extension number and where you want to foward it to. So if you were canceling it on your extension which we'll say is 12 for example then you would press feature 11 12 12.
May 22, 2010 | Lucent PARTNER18 Corded Phone
I need to forward calls to another extension so the other person can get his calls when he is out Norstar T7316
To foward calls from one extension to another, press feature 4 and the extension number of the phone you want the calls to foward to. To cancel call forwarding, press feature #4 or press the cancel soft key.
May 20, 2010 | Nortel T7316E 2-Line Corded Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Can I set up an extension to automatically transfer any calls received to a different extension using the T7316E?
You can transfer any incomming calls to another extension using call forward. On the set you wish to foward, either press your foward key or enter feature 4 the display should ask for an extension to send the calls to, enter receiving extension. Press your foward button or feature #4 to cancel fowarding.
Sep 29, 2009 | NorStar T7316E Corded Phone
Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
Apr 13, 2009 | NorStar Meridian M7310 Phone
Xerox 8200
You can not change the bulbs in the paper pre heater you have to get the whole paper pre heater unit.
Dec 15, 2008 | Xerox Phaser 8500/DN Printer
NorStar Meridian M2616 Phone Logo
70 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
