Question about Dishwashers
The F4 fault code on my Fisher and Paykel Dishdrawer Model DD603 dishwwasher indicates that the "temperature sensor is faulty. Question: where is it located on the machine and how do I replace it?
    Problem Solver:
  • 6 Answers
The temperature sensor is located on the heater plate(looks like a blob of solder with a thin line leading to a blob of solder,The solder acts as a fuse when it "blows"you have to replace the heater plate.The heater plate is located in each draw (get at it from the underside of the draw)there is a grey round plastic piece that has to removed like the back of a watch.Caution you shoild have the power and water off and this is a job best left to the capable!
Posted on Jan 06, 2011
  • TomDicker Jan 06, 2011
    Further to above :There is usually a reason that the temperature sensor fails,in my experience its because the draws electronic controller has cr*pped out,Just replace the heater plate and it will probably just fail again.Fix the root problem not just the symptom.
My Fisher and Paykel dishwasher serial # starts with 88445 ERM - What year was it manufactured? 1995? 2005?
ERM was manufactured June 2005 according to this serial number. The product code (on the model/serial tag) would further refine the dishdrawer details.
Oct 31, 2016 | Fisher and Paykel Dishwashers
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Jan 02, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Oct 04, 2012 | Fisher and Paykel DishDrawer DS605FDSM...
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F4 fault on fisher paykal dish drawer
F4 fault would inidicate the temperature sensor that senses the water temperature is faulty or the heating element is not working.
Looks like you will need a technician to visit and have a look.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Help with and f4 fault code on a fisher and paykel disher
Without the model number I have to guess.
Fault code 'f4' means "faulty temperature sensor or element".
Here is a link to User manuals:
http://fisherpaykelparts.net/index.php?blockitemid=29
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Fisher Dishwashers
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Dishwashers Logo
1,255 people viewed this question
Top Dishwashers Experts
