Question about Epson Stylus C66 InkJet Photo Printer
Red lights flash alternately
I changed the ink & now it won't work, the 2 red lights just flash alterately
  • salahberrich Mar 29, 2009
    arret fonction
  • Anonymous Mar 29, 2009
    flash
  • Epson Master
  • 691 Answers
Your machine has hit the Ink Overflow Protection Counter Limit. Sounds dreadful but fairly easy to fix.
Get this C66 Rescue Kit and follow the instructions. your printer should spring back to life in no time.
Posted on Jul 07, 2008
    Novelist:
  • 110 Answers
Most likely the cartridges aren't seated correctly.
While the printer is off. Try putting your fingers in there and push down the lid.
If that does'nt work, slowly and gently pull the print head to the side so u can access the cartridges. Push them all down and make sure the lid clicks. Then push the print head back.
Turn on your printer
Posted on Aug 22, 2008
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Green light out both red lights flashing alternately
If the lights are flashing alternately then this is the Service Maintenance request by the printer. Usually this is related to the ink pads. You will need to change the ink pads and use a SSC utility.
http://www.ssclg.com/epsone.shtml
Feb 08, 2010 | Epson Stylus C88 InkJet Photo Printer
R200 not working, flashing red lights like ping pong
If the lights are flashing alternately (which I think is what you mean) then your printer is requesting the waste pads be changed or "service required" as it's often known.
The solution is pretty simple and consists of two stages..
1. Download the SSC utility and use it to reset the protection and overflow counters (instructions are available all over the web for this and your printer is compatible but DO NOT use the ink freeze or chip reset functions as they can cause all sorts of problems!)
2. Redirect your waste ink flow to an external tank of some description. There are pre-made kits available of varying types or you can build your own.
All the info you need on this part of the process are available from this forum
Hope that helps and if you hit any problems, please post a follow up comment and I'll do what I can to help.
Cheers
Martin
Mar 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Trouble codes - red and green light flashing alternately
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you want to have a go at doing this yourself, the 820 service manual can be downloaded from here:
810/820 http://www.mediafire.com/?m6ouftizois
Jan 11, 2009 | Epson Stylus Photo 820 InkJet Printer
Power light and red light keep flashing alternatively
If both lights are flashing alternately, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utilit to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus C66 InkJet Photo Printer Logo
261 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
