Question about Dryers
Dryer heats initially but does not maintain heat
    President:
  • 2,468 Answers
If its electrically heated it could be the high-limit thermiostat on the heating element case or the cycling thermostat on the blower housing/if its gas heated,it can be the gas valve coils are weak on the valve body,the flame sensor eye on the burner tube,the high-limit on the burner tube,or the cycling thermostat on the blower housing
Posted on Jan 01, 2011
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
My dryer gets hot for 10 minutes then cools down
Sounds like the dryer is overheating. One of 2 possibilities. The dryer vent hose is blocked or partial blocked allowing for heat build up. The other option is that the Thermostat has gome bad or is mal-funtioning. The thermostat works just like the heat in your house it maintains the temperature called for. In the case High heat meduim heat etc, based on the dial postion or cycle you choose
Feb 28, 2011 | Kenmore Dryers
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Dryer heats to proper drying temperature and then temperature is not maintained and drops off causing long drying time when on timed drying...GE Medallion 850 - bottom heat sensor was cleaned.
you didn't mention if dryer was gas or electric. gas dryer could have bad valve coils which will work for a short time and then fail, cool off and then work again and fail, causing intermittant heat.
May 05, 2010 | Dryers
Initial heat cycle will ignite gas burner but will not re-ignite to maintain heat.
MAKE SURE YOU HAVE GOOD VENTILATION TO OUTSIDE. CHECK THE COILS IN THE GAS VALVES. CHECK CONTINUITY ON BOTH COILS. SHOULD READ 1.3 - 1.9 OHMS. ON THE COIL WITH THREE TERMINAL, MEASURE BETWEEN MIDDLE TERMINAL AND OUTSIDE TERMINALS
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Dryers
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Need wiring diagram for kenmore dryer 110.76712694. Gas-fired unit which ignites initially, but does not maintain heat. Venting unobstructed
Look inside the lid where the timer is. Most all models have schematics attached inside somewhere. Good luck!! Dont forget to rate my comment!!
Aug 19, 2008 | Dryers
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
Top Dryers Experts
