Question about NetGear DGN2000 Wireless Router
No lights on the modem ,its not detecting power,dsl,wireless and internet light. I tried resting it still doesnt work
    Novelist:
  • 125 Answers
If your modem do not show any light even after resetting it, its obvious that the modem has gone bad. But try connecting the modem in a direct wall outlet to make sure that there is no problem with the socket.
Good Luck!
Thanks in advance!
Regards,
Prema.
Posted on Dec 29, 2010
  • Keith001uk Jun 14, 2011
    The same thing happened to me i switched off my router to let it cool down for 1h tried switching it back on and only the ethernet ports light came on 1.2.3.4 the no lights at all. I fixed my by putting it in the sun for 30mins till it was really hot then i plugged it in a the power light was there and now its working fine. Hope this helps anyone else
This solutions works for me. it happend the same. no lights at all except for a moment at start up. I heated the router with a hairdrier. after few minutes it worked again.
Posted on Apr 01, 2013
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
I have a netgear range max, it has been working fine. Just last night nothing wireless in my house works. Cable modem works. Power light on netgear box is green. "i" icon is flashing green,...
You need to reset and reconfigure router
please follow the steps to reconfigure router
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Regards,
Prakash
Apr 08, 2011 | NetGear WGT624 Wireless Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Hiee I am using netgear N300 jwnr2000 router. The router worked fine for few days it has suddenly stooped working.Any of my wierless devices are not able to detect my router since the wifi in been...
Unplug both your DSL/Cable Modem, and the Router from power. Wait 30 seconds. Plug in power to DSL/Cable Modem only, and wait for it to connect. then plug in power to Router, and wait for it to start up. Give it about 1 min. If the lights are still not on, you may need to reconfigure your router. If this does not work, connect your cable/DSL modem to your computer directly, and power cycle it again. Once it is online, check to see if you can get online, if you cannot, contact your internet service provider, as you have ruled out a problem with the router.
Dec 28, 2010 | NetGear WNR2000 Wireless Router
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Sep 16, 2010 | Computers & Internet
Strong signal but cannot log on to internet. Also uther wireless works and logs on. also direct wire from modem thru router to computer does not work. if i go directly from modem to computer the compter...
it seems that you need top reconfigure your router
following are step to reconfigure router
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
16. Click Apply.
regards,
prakash
Feb 10, 2010 | NetGear WGT624 Wireless Router
Set wep now cant login to enternet or router, and no lights
it seem that all setting on router has mashedup
need to reconfigure from begning
16. Click Apply.
Jan 14, 2010 | NetGear RangeMax WPN824 Router
I am trying to configure my netgear router to work with my dsl motorola modem
You can access your wireless router by first running you ethernet cable from pc to wireless, then in address bar, type 192.168.1.1 and this will enter the wireless router's software. If it asks for username and password, try typing admin for both.
Sep 03, 2009 | NetGear WGR614 Wireless Router
NetGear DGN2000 Wireless Router Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
