Question about Electrolux Microwave Ovens
What are the error codes for the tappan microwave model tmv151fs and how do you reset or repair the microwave?
MicrowaveSvc
  • 9098 Answers
SOURCE: User manual for a Tappan mod TMV151FS
You can download your owner's manual here.
Posted on Jan 01, 2009
  • 4088 Answers
SOURCE: Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Posted on Aug 19, 2009
hardrocko
  • 1476 Answers
SOURCE: Tappan over range has no heat!
You have a bad high voltage diode, bad filter capacitro or a bad magnatron. The diode and capacitor does not cost very much. You can get them at www.mcmelectroncs.com . Replacement would mean removing the unit from under the counter, remove the case. Locate the diode and capacitor. They should be near the power section and the diode is attached to the chassis and one side of the filter capacitor. After replaceing both parts if the unit will not heat you would need a new magnatron. The part is fairly expensive but depending on the cost of your unit it may pay to replace it. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Posted on Feb 27, 2010
SOURCE: I am looking for a new door on my Tappan over the
I have one!!
Posted on Apr 28, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: tappan over the range microwave tmv151fs. keypad
"SE" means you have a shorted membrane keypad.
There are three ways to fix this:
The cheapest but most difficult is to remove and replace the membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Here are the part numbers, which you can order from the Pros here (our favorite supplier) or via the Sears Parts Direct Web site.
MEMBRANE KEYPAD
5304456071 (black)
5304456071 (white)
You can replace the control panel frame, which comes with a new keypad already installed.
This costs is a little more, but is much easier.
CONTROL FRAME WITH KEYPAD
5304456078 (black)
5304456079 (white)
The simplest way of all is to replace the whole control box.
ENTIRE CONTROL BOX
5304456080 (black)
5304456081 (white)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Posted on Oct 18, 2011
Tappan Electrolux tmv151fs microwave/rangehood. turntable and cavity light intermittent (but work/fail in unison), all else work ok
Either a wiring problem or worn contacts on the relay that powers the two would be possibilities.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 24, 2016 | Microwave Ovens
Everything on our microwave works except the most important part-its not heating. TMV151FS
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 09, 2011 | Tappan Microwave Ovens
My Tappan TMV151FS MIROWAVE OVEN DOES NOT WORK THE MESSAGE READS (SE) IN THE LCD WINDOW CAN'T LOCATE MY OWNERS MANUAL CAN YOU GIVE ME ANY INFORMATION ON THIS PROBLEM THANK YOU LEO LAFLER
The most economical repair (and a pretty simple one) is to replace your entire controller assembly.
Model TMV151FBA is black and model TMV151FSA is white.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You would order one of these here:
PART DESCRIPTION COST
5304456080 Control Box, assembly, black $145.14
5304456081 Control Box, assembly, white $149.42
Sep 07, 2010 | Tappan Microwave Ovens
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Filter replacement
That's covered on page 20 & 21 of your owner's manual under the heading"CHARCOAL FILTER REPLACEMENT"
1. Unplug oven or turn off power at the main power
supply.
2. Open the door.
3. Remove the two vent grille mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number from the tag on the oven here.
Feb 16, 2009 | Tappan TMT104E1 Microwave Oven
Jan 01, 2009 | Tappan Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
