Question about Cameras
Hi i have sdhc memory card insrt the fujidigital camara is show error plz solve the problem....thanks
  • kakima Dec 29, 2010
    What model camera? Some Fuji cameras only take SD cards, not SDHC cards.
  • raj_7929 Dec 29, 2010
    fuji digital av100
    Problem Solver:
  • 16 Answers
Need more info but have you reformatted the SD card or tried another ?
Posted on Dec 29, 2010
    The AV100 does accept SDHC cards. Have you formatted it?
Camera saying memory full but card brand new
Not only the size is important, the manual says SD max 2 GB.
But even a 1GB SDHC card won't work, because the camera is not compatible with SDHC and SDXC.
They used to make SD cards up to 4 GB, but most new cards from 1 GB and up are SDHC and above 32 GB the cards are SDXC. Older camera's can't handle these cards, although they look the same.
To read more and to understand compatibility from device versus Memory card, read this:
Secure Digital Wikipedia the free encyclopedia
Apr 10, 2015 | Samsung Digimax D73 Digital Camera
I purchased a sdhc 4gb memory card for my Panasonic DMC-LZ2 Camara and when I put it in I get a message that says memory card error. Do I need to format it? and how do I do that
The DMC-LZ2 uses SD and MMC cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You will need to use SD cards 2GB and smaller.
Dec 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
My pny sdhc card wont work, my laptop wont read it and when i put it in my camara it sais card error
You haven't said which camera you have, but your problem is almost certainly a hardware incompatibility. SD cards and SDHC cards look the same and fit the same slots but are technically different.
Your fix is to either stick to a maximum SD capacity of 2GB (some cameras can only cope with 1GB or smaller) or to replace your camera with a later SDHC compliant model and to use an separate (cheap) external SDHC compliant card reader on your laptop.
Jun 19, 2010 | PNY 4GB Secure Digital High Capacity...
Camara screen shows"card is locked" and is not allowing me to take a picture
There are several possible causes for "memory card locked" or "memory card error". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, and the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
May 28, 2010 | Canon PowerShot SD850 IS Digital Camera
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
WORKING CAMERA WONT TAKE MEMORY CARD
It's possible the camera won't take an sdhc card. Or maybe you just need to move the slide switch on the side of the card to unlocked or that you need to format the card in the camera.
Dec 26, 2009 | Cameras
I have a kodak M1033 camara with a SD HC PNY optima 240 HD 16 GB and the camara says internal memory is full and is only 1/2 minute video in the camara please help
Hi!
Sonds like the camera hasn't switched to the memory card. Go to setup and set memory to Auto not Internal. If that doesn't help, it's possible that the camera doesn't support 16GB card, but it should give you a card error then, so check the memory settings first.
Tom
Oct 06, 2009 | Kodak EasyShare M1033 Digital Camera
Samsung S630 Digital Camera, Card Error and Format Error
you have several options:
1. see in the specification details of your camera what memory card is compatible for camera. for S630 it is SDHC/MMC/SD card (Up to 4GB Guaranteed). see if you're using memory card within this capacity and type. If you're using a different memory card type and capacity, try to use memorycard that is compatible with your camera.
2. try to use memory card to other devcie like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
3. try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error meassage, camera needs service.
hope these options solve one of your problems. c",)
Dec 29, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
