Question about Ovens
Neff Double oven 1410/1420
Hi
The main oven fan is intermittent. It will come on full speed sometimes. I can nudge the blade round and it will pick up speed then stop. It doesn't seem to be the actual fan/motor itself as it will run full speed sometimes.
Thanks for any help, please don't suggest I get soemone in to fix it as I am perfectly capable in replacing motors, checking for voltages etc.
David
  • 725 Answers
I think you got it david ..
check voltage to the motor at low and high.. if voltage is good.. them it must be the motor...let me know
Posted on Jul 08, 2008
Tip
Common heating faults with Neff U1421 Double oven,
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1421 Double circotherm Electric Oven
Tip
Common heating faults with Neff U1461 Double oven
on Jan 19, 2010 | Neff U1461 Double circotherm plus Electric...
NEFF U1271 Oven overheating
Hi it could well be the thermosat has stopped working
Jan 24, 2010 | Neff U1721 Double circotherm Electric Oven
Neff circotherm doudle oven main oven fan working
It is more than likely that the oven element has failed.
You will it located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 09, 2010 | Neff B1641 Single circotherm super...
Tip
Neff U1452 Double oven Common heating faults,
For all Free appliance repair videos visit our VIDEOTUTORIALS
1, If the Neff fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1452 Double circotherm plus Electric...
Tip
Common heating faults with Neff U1661 Double oven
on Jan 19, 2010 | Neff U1661 Double circotherm super...
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
I need to take off a fan from a neff oven,how do i remove the fan?
Remove inner rear panel of oven.
Unscrew nut clockwise that secures the fan blade to the motor, undo screws that secure the motor. and replace same. You may have to remove main back panel to access fan motor screws and terminals.
please leave a fixya rating for my solution.
Thanks.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
130 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
