Question about Fujitsu Heating & Cooling
When the airconditioner is on, the big unit (blower) outside does not work> When we finally got it to work, the air coming out is not cold, it's just like a blower, it's like the air it is blowing is from an electric fun. We have ducted airconditioning, Fujitsu ART series and it's only 2 years old.
  • 2,133 Answers
Check the compressor is working with exact amps. If not short of gas or no gas. Check thermostat setting 23 degree with cool mode.
Posted on Dec 29, 2010
I have an Amana heater/airconditioner (Prestige I think) that is not cooling. The outside compressor fan was not spinning, so i I changed the capacitor on the unit. It now spins, yet vent air not cold
If that fan stopped your compressor overheated, shut off on thermal overload. Carefully cool compressor with water hose and restart. If the big copper is cold ,small copper warm, compressor is running. Check capacitor on compressor
Jun 06, 2016 | Amana Heating & Cooling
Fan not worhing when heater is on
You can cover the system as long as the vent is clear if this is a gas package unit & not a heat pump.
Jan 15, 2015 | Heating & Cooling
How come my AC is on but the air coming out is not cold?
Check the refrigeration lines coming off the outside unit. One should be very cold and one relatively warm. If one is not very cold, then the compressor is not working. Usually you can hear it when it is running. The condenser fan in the outside unit should also be operating. If the compressor and fan are operating, but the refrigeration line is not cold, you probably have a refrigeration leak and have lost the coolant. You will need a service tech for the repair.
Jun 02, 2013 | Emerson 1F95-1277 Big Blue 12" Touchscreen...
My through the wall whirlpool air conditioner has water sprinkling through where the cold air comes into the room is my air conditioner broken??
No... either the drain hole is plugged or the unit is tipped forward instead of backward...make sure that the unit outside the window is lower then the inside by just a bit... The drain holes are usually in the back outside corners and often they plug up with dirt or debris...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Whirlpool Designer ACU109PR...
Cant keep cool
You need to check that tour filters are new. Then check that air is coming from the vents and is at least 15 degrees cooler than room temp. If no air coil is frozen, or blower motor and run cap are not working. If frozen than turn system to off and fan switch is on until you feel air through vents.
You'll need to make sure the outside unit is runing and the larger copper line is cold like a can soda. If it's cold but is freezing up, it needs to have a charge added. If its running but not cold and the fan is not running or the compressor isn't running it could have a blown capacitor. If its not running at all check. the circuit breakers and reset them. And a good idea to keep the outside unit washed with water,and that it is clear of weeds and stuff.
Jul 10, 2010 | Goodman CLQ36AR49 Air Conditioner
My heat does not come on in my car. could it be the blower?
if does blow cold air then its the door for outside air to come in is stuck if there is no air then it is the blower motor
Dec 21, 2009 | 2000 Pontiac Grand Am GT
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Air conditioner not blowing cold air
Hi Deb,
The Suction line is the larger of the two, and the smaller is a liquid line. That said the ruber you refer to is insulation and does a very important job so do not remove it . I need to know if the outside unit is clear and free from obstruction and debris? have you noted any other worring sgns lately? ie is this system constantly running?
May 20, 2009 | Goodman CLJ36AR42 Air Conditioner
Heating & Cooling Logo
182 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
