Booting from former slave drive
Previous 'C:' drive was placed into another PC and made into slave drive. Now need to restore to original 'C:' status in previous PC. It will not boot now and says reinstall the "system32 driver because couldn't find or its corrupted? Can this restored without damaging old data? If so, How?
Thanks,
Terrall
    Champion:
  • 214 Answers
try boot to safe mode, and do a system restore.
if it not worked let me know
good luck
Posted on Jul 07, 2008
I need to factory restore
Not enough information to answer. Need manufacturer and specific model number before we can help.
Generally, though, laptops come with one of three ways to restore.
1. The manufacturer supplies a restore disk. This can be a self-booting image of the original load, or it can be an OS disk and an accompanying drivers disk that needs to be installed to restore the unit.
2. The manufacturer provides an application on the drive that the user is supposed to use at the time of purchase to create a set of recovery disks. This application is usually a 1-time-only thing and you cannot make multiple recovery sets with the app, but you can burn copies of the disk(s) you make.
3. The manufacturer places a hidden recovery partition on the hard drive that allows the user to restore the original factory image. There is usually a hotkey combination written into the BIOS that will divert the boot to the recovery sector when pressed at bootup.
Some manufacturers offer both options 2 and 3. But if you got a set of recovery disks at time of purchase, chances are there is no recovery partition on the drive. Recovery partitions are nice and convenient until the problem is the hard drive itself.
If you can provide a specific model number, we may be able to better determine which type of recovery option(s) are available for you PC.
Dec 01, 2015 | Gateway MX Computers & Internet
Trying to restore os
Tap F1 when booting, to enter the BIOS Setup utility, and make your CD/DVD drive the first boot device. However, I'm not sure you need to put the system disk in to restore. This machine may have a hidden restore partition. Try this. Remove the disc, and invoke your restore by pressing F11 when booting, and follow the on-screen instructions. See page 49 of the manual for how to restore the computer to the original configuration... http://www.manualslib.com/manual/253462/Gateway-300x.html#product-GT5056
Jun 22, 2014 | Gateway GT5056 PC Desktop
How to set a toshiba hard drive to slave?
Power off the Toshiba laptop. Remove the power cord and the battery.
Turn the laptop upside down and remove the panel where the hard drive goes with a screwdriver.
Depending on the model of Toshiba laptop being worked on, this may include the entire bottom panel, a panel covering both hard drive slots or a panel covering the empty second slave hard drive slot.
Install the second hard drive by inserting it into the open slot.
Replace the opened cover.
Replace the battery and power cord.
Turn on the computer.
The second hard drive is automatically configured as the slave drive.
Depending on the operating system and previous status of the slave hard drive, it may need to be partitioned or formatted before being used by the operating system.
hope this helps
Sep 13, 2012 | Toshiba Computers & Internet
How connect slave drive dell computer?
I assume you are trying to add a slave drive to a Dell DESKTOP? If so, is it an IDE drive (standard hard drive). To that you will find a jumper plug, usually beside where the cable plugs in but sometimes on the opposite side. The jumper options are usually listed on the drive but what you will need to do is place the jumper plug in the slave slot. You will also need to move the jumper plug on the original hard drive to the master slot. That always seems to work the best for me. However, you can try adding plugging the slave drive into the next open slot on the IDE cable, which is already plugged into the original hard drive. If you get lucky it may automatically recognize the new drive as the slave. You may need to setup/configure the BIOS to set the master and slave drives. To check BIOS setting, hold F2 or F10 when you turn on/boot the PC.
Apr 20, 2012 | Dell Computers & Internet
I want to reset my compaq presario cq60-215dx notebook pc
Hi
More information needed.
What do you mean by "reset"?
If you mean you want to restore it to a previous setting before, for example, a virus infection:
start > all programs > accessories > system tools > system restore > restore my computer to an earlier time > select date and event on calendar and event schedule > restore.
If you mean restore your computer to factory default settings:
When the computer is booting, you will see, at the bottom of the screen, an F (function) key that takes you into the Recovery mode.
Recovery will wipe everything else off except Windows and the programs and drivers that the computer originally came with.
Hope this helps.
Aug 24, 2011 | Compaq Computers & Internet
I would like to restore to factory setting. I do not have a recovery cd or the original cd's that came with the laptop
You will need to purchase a new OS disc and place it in the DVD drive booting from there to format the hard drive and put a fresh OS on it.
Don't forget to install downloaded drivers from the manufacturers web site.
Hope that helps.
Feb 02, 2011 | Computers & Internet
I have an ibm that i would like bring back to factory status
hello hershyhunk to fully restore a PC to factory settings/defaults you will need to reinstall the operating system. to do this you need your recovery disks that came with your computer.
WARNING!! All of the data on your laptop's hard drive will be permanently erased when you restore it to its original settings. Before starting the restore process you may want to save any data you still need to an external drive such as a USB flash storage device.
Depending on the specific brand and model of your laptop you may need to select different options to restore the computer to its original settings. Check the manual that came with your laptop to find the specific menu options you need to select. Some computer manufacturers include an icon in the Start menu for restoring the laptop to its original settings without having to use a separate recovery disk. Double-click the icon and follow the instructions on the screen to start the restore process.
  1. Place the operating system recovery CD that came with your computer into the CD or DVD drive. Restart the computer.
  2. Wait for the computer manufacturer's logo to pop up on the screen. Press the keyboard key that brings up the recovery menu, which is usually "F2," "F8," or "Ctrl" and "F11" pressed simultaneously.
  3. Select the specific language you want the operating system to use from the menu at the top of the screen. Select "Next."
  4. Choose the option labeled "PC Restore," "Repair Your Computer" or something similar. Click "Next."
  5. Select "Restore" and then click "Enter" to start the process. Click "Restart" once the process has ended to boot the restored computer to its operating system.
Nov 16, 2010 | Computers & Internet
HOW CAN I RESTORE TO PURCHASE DATE?
The most effective way to restore a PC to the original settings when it was purchased is to reformat the hard drive. This would need to be performed by a technician or knowledgeable individual. You can reinstall windows easily enough yourself, though, by inserting the windows CD at startup and booting from the CD. You can then follow the instructions provided to reinstall windows.
Jan 07, 2010 | Computers & Internet
I had tried to flash my Gb-k8vt800m board using @Bios and got a bootblock lock up. I had saved the original bios to a file on my desktop prior. I now have that hard drive as a slave in second identical...
99.9% of all computers will never need the bios flashed.
This is printed on the bottom of the gigabyte web site.
Warning:
Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction.
The problem with your computer has nothing to do with the hard drive. You need to repair the bios. There is a way to flash the bios without booting into Windows. I'm pretty sure that a floppy drive is involved. You're going to have to figure out how to flash it back to your original bios that you have saved on your hard drive without booting into windows. There is some info on gigabyte web site about flashing bios. My internet connection is bad today and I can't download very well from that site or I'd give you an address. www.gigabyte.com.tw
Also remember that when you flash the bios all the settings in your bios reset. You should enter setup and click on the "load optimal defaults" Then you need to make sure date and time are right. Need to set boot options. Check that the clock ratio is right for CPU. There are a lot of options in there that can be keeping your system from booting it isn't necessarily a failed bios flash other than not getting the settings right after flashing.
Nov 25, 2009 | Intel Motherboard
Need jumper diagram for motherboard
Check that the hard drive is set to "slave" on the jumper settings where you connect it (if it's IDE). Also, check the boot order in the BIOS (or setup as it may be called when booting up) to make sure that they computer's not trying to boot off the new drive rather than the old one. I don't think the jumpers on the motherboard will help you at ALL. Drive jumpers are the only thing and as mentioned - set the new drive to SLAVE and make sure the original drive is on MASTER (this is usually all recorded on the top of the drive on the label)
Dec 15, 2008 | Dell OptiPlex GX520 PC Desktop
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
