Question about Toshiba Satellite L505-S5966 Notebook
My toshiba L505 S5997 is not recognizing the wireless network. The genius at Toshiba said to restore my backup or return it to factory specs. Neither solutin worked. The device manager says the network card is working properly but the vomputer still can't recognize any wireless network and when I go to try and sign on it says no connections available, I think it is some sort of switch somewhere. Any ideas?
SOURCE: toshiba satellite a135-2326 usb not recognized
HEY HEY HEY!
guess u wat? my usb came back to life! just like that! may be God exists afterl all, does He???
Posted on Aug 15, 2008
jessee007
  • 310 Answers
SOURCE: Toshiba P30 - I can't complete the reformat/restore operation
pull out the cd drive and reboot. then go to programs folder and un install any new dvd or cd programs that where just installed. reboot . then try to install your drives again
Posted on Nov 17, 2008
  • 55 Answers
SOURCE: Wireless not working
first check whether the wireless switch on ur laptop is turned ON orn't.it should be kept always on
Posted on Nov 22, 2008
patemi
  • 366 Answers
SOURCE: lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Posted on Jan 15, 2009
leecom72
  • 4806 Answers
SOURCE: Wireless network adapter won't turn on
Hi there.
It sounds to me that the Atheros wireless card may have gone bad, in some cases this does happen.
Check in the bios to make sure that the wireless adapter is enabled, apart from that i cannot suggest anything else as you have just about troubleshot everything a PC technician would do before coming to the conclusion that its the hardware which is at fault.
If the machine is still under warranty then please take advantage of that, if not then a reputable PC repair shop will be able to fit a new card in the laptop and they will make sure it works before it comes back to you.
Good luck and thanks for using FixYa!!
Posted on May 22, 2009
I'm using a Toshiba L505-10W. recently i've installed windows 8 consumer preview. my wireless doesn't turn on and the flash cards doesn't work either. realized that even my bluetooth d
The drivers for the hardware don't exist for windows 8. You need to format. turn on holding the 0 key. follow steps to set to factory defaults, save your pictures and documents first cause this will erase them.
Jul 01, 2012 | Toshiba Computers & Internet
My Toshiba L505 ES5018 FN keys is not working
Hello. It's possible the driver for the wireless card(network interface controller) was not installed properly. Try to download the drivers from Toshiba website and install on your laptop. You may get the WiFi Driver from this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2520800&rpn=PSLU0U&modelFilter=L505-ES5018&selCategory=2756709&selFamily=1073768663
There's two WiFi Driver available, try to use the Realtek first and if it doesn't work try the Atheros. If WiFi driver installed correctly you should no longer see the "!" symbol and you will be able to enable wireless on your laptop using FN key combination.
Hope this works for you.
Nov 18, 2011 | Toshiba Satellite L505ES5018 Laptop
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
I need to restore my laptop back to factory because I can't access my browser. Please help me.
Your computer usually comes with a restore disk(s) If not call toshiba and ask for restoration disk which bring the computer to original factory status!
Sep 03, 2011 | Toshiba Computers & Internet
Toshiba satellite l505-13v drives usb not working
Try this: log off then turn off lap top, insert the USB devise into the USB port, power / turn on and log in it should show to recognize new hardware and work.
May 29, 2011 | Toshiba Satellite L505-S5966 Notebook
Need to wipe out laptop how do i get the recovery downloads
Is your computer still working? You need to create the restore disks using TOSHIBA, TOSHIBA Recovery Disk Creator.
You may have to contact TOSHIBA if you want to purchase restore disk to put it back to the factory condition.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&moid=2350215&src=EXPL
Feb 01, 2011 | Toshiba Satellite L505-S5966 Notebook
Toshiba Satellite L505-S5966 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
