Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
The fridge light flickers and makes a strange knocking noise when screwed in. I put in a new light hoping that would help, but it didn't work. The mechanism which displays the freezer and fridge setting turns off when bulb screwed in, but comes on again and the noise stops when the bulb is removed from the unit.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
I suspect the main control down by the compressor may be faulty. Without a model number I can't give you specific information, but these controls have a pretty high failure rate. The "knocking" you describe is likely the relay(s) chattering. The board controls every function on the refrigerator, including the turning on of the lights. Have someone screw the bulb in while you are behind the refrig listening down by the compressor area. The control is mounted to the LH side of the compressor in a plastic case.
Posted on Dec 29, 2010
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
Fridge lights are buzzing and flickering
You need to replace the electrical control board. It's an easy fix. About $75 for the part. No electrical work necessary. Just unclipping and re-clipping wires into their ports. You do not need a repairman to do this! (I'm a 33 yr. old female, so please forgive my lack of technical terms in the post) I ordered one from AppliancePartsPros.com. It came in two days.
1. Pull out and UNPLUG the fridge.
2. Take out the screws that hold the bottom back panel on
(The electrical contol panel is located inside a white box attached to the lower left corner. )
3. Remove the screws that hold the box in place
5. Remove the bunch of wires out of the clip on the side of the box and pull the box out. Open it by releasing the clips on either side.
6. Disconnect the three sections of wires that plug into the board
7. Remove old board out of the housing
8. Insert new board,
9. Reverse above steps to complete installation.
Note: What triggers the buzzing sound is the door being opened. If you want to stop the sound and prevent the electrical current from going to the fried board until your new one comes, put a piece of tape tightly over the switch that pops out when the door is opened (located inside the unit near the door hinge).
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
mr.grzz
Jan 24, 2009 | Ruud UAMB Air Conditioner
Knocking noise coming from Whirlpool Gold refrigerator
I also have a new Whirlpool Gold fridge (bottom freezer with French doors) and it was making a knocking sound. The knocking sound would start when the fridge kicks in and starts running to cool, and would last for about a minute or less and be a slow knock.
I called Whirpool customer service since it is new and on warranty. They sent out a technician and he said the knocking is from gas/air built up in the copper tubing for the freezer because the copper tubing is too cold, and when the fridge first turns on it forces the air through, making the knocking sound.
His "fix" was to adjust the copper tubing so that it is closer to the heat of the motor/compressor and heat of another copper line so that the cooler line stays warm so the air/gas doesn't build up. His fix worked slightly, but the fridge is still knocking, just not as bad and not as long - it knocks fast for about 5 to 10 seconds instead of a minute.
Going to call customer service again soon and see where to go from here.
Dec 15, 2008 | Refrigerators
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
Whirlpool gs6shexns00 fridge
I had a very similar problem- flickering light bulbs, shorting-out noises, electronic temperature displays not working. I had to replace a small circuit board (the "Electronic Control Board") accessed from the rear of the fridge. A relatively easy do-it-yourself job.
Refer to this link at PartSelect.com:
http://www.partselect.com/PartDetail.aspx?Inventory=2180152&SourceCode=1
Oct 26, 2008 | Refrigerators
Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Just had new brake shoes fitted and now have strange noises coming from rear wheels also abs light is on
whoever replaced the shoes has probably damaged the sensor by knocking it or has taken it out,[dont have to] and not plugged it in again. im picking it has been knocked. they dont like that too much.and that will cause the light to come on. or the brake pad wear sensor [on the rhr side] is damaged or not re installed. & the strange noise could be incorrectly adjusted shoes or not installed correctly.
Aug 08, 2008 | BMW 318 Cars & Trucks
Fridge making "knocking" noise
Remove the light shield and there should be screws under it. Remove the air tower in the back, it snaps in and there is 2 screws behind that as well to remove the damper housing that sits behind the light. Also not sure what your model is but some models have 2 air ducts that run up each side, they come out after the light shield is removed by sliding foward and then pulling down. After the screws are removed in the upper plate the light assy will snap out and there is 2 quick disconnects on the wires.
Jul 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
326 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
