Question about LG DVD 6183 DVD Player
My LD DVD player( Model DSI 8555) does not load the disk. It just shows loading for about 5 mins and then displays a message as 'No DISK'
dsom
  • 56 Answers
SOURCE: DVD player cant read DVD media
.Vob files contain audio, video and subtitles all together.However, most MPEG-2-capable DVD players don't support subtitle tracks. I guess your DVD player is in the mentioned majority. That's why you can only play them in your computer drive.
Posted on Apr 24, 2007
SOURCE: Disk not detected
Hi, had the same problem myself, turns out (after some investigation) that the motor that spins the dvd wasn't getting power. I carefully pulled out the smaller ribbon cable that goes to the small circuit board beneath the drive caddy, then pushed it back in. Put it back together, turned it on and off it went! Yay!
Posted on May 31, 2008
  • 11 Answers
SOURCE: update with disc model BH100
Download the firmware file and how to document here:
http://us.lgservice.com/index_b2c.jsp
Follow document to create a disk, and update the firmware.
Posted on Feb 05, 2009
SOURCE: Front load DVD player will not accept the disk.
Invest in a new DVD player...it will be much simpler, will cost roughly the same amount AND save you the hassle of finding someone to repair the broken drive gear (cog) on the insertion/eject roller (if all else is known to be working). You will find it on the left side of the DVD bay connected to a tiny white worm gear and even smaller reduction gear. If you are handy with a precision hobby mill, you can easily turn a replacement gear out in relatively short order with only the tedious tasks of disassembly and reassembly of the shaft end to deal with. Be certain to unplug and discharge the capacitors in the machine before messing about the inside of the player (UNplug player and press the I/O, "on button," twice). One sturdy knife blade, one standard philips head and one small philips head screwdriver will be all you need for disassembly. If you are capable of opening the chasis and the DVD housing, you will be capable of removing the speed nut from the shaft of the insertion/eject roller and of deciding from there what you should do. Good luck.
Posted on Sep 04, 2009
deejaykrish
  • 63 Answers
SOURCE: no disk detected
No disc error is usually caused by dirty optical lens or a faulty lens. Turn it off, unplug it, then try cleaning it with a very soft dry cloth and then try playing a cd which has no scratches.
The blue color part, that's called optical lens. It looks like a glass but its not a glass, its a plastic cap for the laser to go thru to read the discs. Never apply any wet solutions on it. Just use a soft dry cloth to rub off the dirt on it. If u absolutely have no idea what im talking about, then take it to a local repairing store to get it fixed. If the cost is too expensive, then dump it and get a new one
Posted on Jan 17, 2010
My pioneer DVD is not working...it is showing NO DISK after loadi
try going into your hardware menue and see if its set on manual for videos
Jul 17, 2010 | Pioneer AVIC-D3 Car DVD Player
"No Disk" message on front display
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Dec 27, 2008 | Pioneer DV-343 DVD Player
DVD will not load
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Dec 25, 2008 | Daewoo DVG-9200N DVD Player
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
ERROR MESSAGE.....
had the same LD FVU (Load FVU or firmware disc) message and fixed it this way: download firmware from http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP and make firmware disc and insert. After it loads and updates, you need to activate your remote again. When the message SET 1 appears, on the remote press ENTER and 1 together for 10 seconds. Done.
Jun 24, 2008 | Panasonic DMRES15 DVD Recorder
DVD will not load/format new disk
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
Mar 25, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
Disc won't load and then shows weird symbol in right corner
Check the black spindle that holds the disk it may be cracked or broken or the little spring tabs are broken. If this is the problem when the disk spins it lifts up and the head doesn't read the disk, this is what has happened to mine. I am trying to locate the part but so far have not had luck finding it.
Sep 17, 2007 | Audiovox D1708 Portable DVD Player
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
LG DVD 6183 DVD Player Logo
82 people viewed this question
Computer Repairing
Computer Repairing
