Question about Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive
Maxtor DiamondMax 10 6L300R0 password unlock - Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive
SOURCE: Maxtor diamondmax 10 jumper settings
http://www.tacktech.com/display.cfm?ttid=379
or
http://www.tacktech.com/images/articles/379/mxo_ata_jumpers_2.png
Hope this helps ;-P
Posted on Sep 25, 2008
  • 72 Answers
SOURCE: My Device Manager sees my Maxtor Diamond Max 10
Yes, If your partition isn't being recognized than windows has no way of reading the information. thats why windows create partitions to determine the amount of space and data being used. it anything try to access it in my computer and see if you can. if you can its possible to get you info, i recommend ananother external to transfer the data to or if its not that much info put it on a flash drive
Posted on Jun 17, 2009
bob_computer
  • 3153 Answers
SOURCE: Maxtor 6L300R0 External Enclosure Problem
It may be a power supply issue but before you take it back to exchange see if any of the hints below are of use.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
  • 41 Answers
SOURCE: What is the master password for a Maxtor QuickView
In all honesty Hard drives do not have any passwords. Maybe you need to re-declre ownership of the contents inside the disk to gain access to the files.
Microsoft windows: http://support.microsoft.com/kb/308421
Mac os X: highlight the drive and press +i to "get info" the last patch of settings on the window is permissions add yourself to the permissions of your maxtor drive with read/write/access and apply to all enclosed items. close the window. eject the drive, re-connect and get your files.
Posted on Nov 07, 2009
astrotheque
  • 4 Answers
SOURCE: what are the jumper setting for slave on maxtor diamondmax plus 9
This web page shows the jumper settings you require.
http://www.google.com/imgres?imgurl=http://www.seagate.com/staticfiles/images/support/en/us/mxo_ata_jumpers_rev.jpg&imgrefurl=http://forums.macrumors.com/showthread.php%3Ft%3D387061&usg=__oBf6Czrk9E5_4ovUuuyxJCl68fY=&h=411&w=850&sz=83&hl=en&start=3&itbs=1&tbnid=J_I6lp0cCbuIwM:&tbnh=70&tbnw=145&prev=/images%3Fq%3DJumper%2Bsettings%2Bold%2BMaxtor%26hl%3Den%26sa%3DG
Posted on Dec 01, 2009
Maxtor diamondmax plus 9 hard drive not seen by computer
I'd say you did a good job troubleshooting. Replace the drive.
Dec 29, 2012 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
What is the jumper setting to service (format) the diamondmax plus 9 disk?
This document might help you:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/diamondmax_plus_9_manual.pdf
Oct 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Need to know the capacity of A Maxtor internal drive SN:A60PVPVC Ndl:91303D6
The 13 GB Maxtor 91303D6 internal 5400 RPM hard drive can be connected via IDE. This 3.5" drive is designed for use with Windows. The 91303D6 is a drive with 512 KB of cache.
13GB EIDE ULTRA DMA/33 3.5LP 5400RPM
Aug 08, 2010 | Maxtor Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
What is the master password for a Maxtor QuickView DiamondMax Plus 8 40 gig hard drive?
Nov 07, 2009 | Maxtor Hard Drive
My hard drive is going bad. So says my HP Compaq dc7100 SFF
Instead of posting here, why don't you look for a dealer.
You can buy hard drives just about anywhere now - and it doesn't have to be Maxtor.
Oct 18, 2009 | Maxtor DiamondMax Plus 8 40 GB Hard Drive
Jumper setting for maxtor n256 diamondmax vl 40 5400 rpm
There is usually a diagram on the drive showing the jumper configuration.
Mar 16, 2009 | Maxtor Hard Drive
Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive Logo
182 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
terminalcon
Jerry Umali
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
